Question about Numark ttUSB Turntable
Playback Problem I just purchased my TTUSB turntable, and it works fine when I'm recording using the EZ Converter, but something happens to the files when being converted and exported to itunes. When the file shows up in itunes, it is just static. I just have the USB going straight in to my computer, and i can hear the music fine as it is recording, as well as see the levels going up and down the eq things. I don't have the RCA cables plugged into anything, but in the manual it says they don't need to be plugged in for you to be able to record. I use MacOSX 10.11.4 Any ideas? Thanks! -Marissa
  • hellomariss Oct 06, 2008
    m4a i think. I'm not at my own computer, but i'm 95% sure that's what it was.
    I then tried converting them to CAA, which is what i noticed the rest of my itunes files are, but i suppose the damage had been done already, so it didn't fix anything.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What format are the files being recorded in?
  • 2,794 Answers
They should be recording in mp3.  Then converted into ITunes using AAC.  Itunes will play MP3 format from the turntable.  The best thing to do is to record in that format, then test the files before converting them.  That way you can find out if the problem is with Itunes conversion or the turntable.
Posted on Oct 07, 2008
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
Nov 16, 2017 | Numark ttUSB Turntable
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Jul 25, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Need drivers for my ION Audio USB Turntable
Hello
USB audio turntable can be found on this site: Driver Update. have a nice day
Jun 22, 2009 | ION Audio iTTUSB Turntable
EZ Vinyl Converter produces file that doesn't work
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
Jan 12, 2009 | Televison & Video
Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Jan 10, 2009 | Numark ttUSB Turntable
Numark ttUSB Turntable Logo
374 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
