I need help in removing the started to replace it.
1. disarm the air bags if equipped. 2.then disconnect the negative battery terminal .3. next remove the positive battery terminal and battery. 4. remove the ignition igniter if equipped. 5. remove the air cleaner assembly. 6 disconnect the starter motor and solenoid wiring from the starter. 7 then remove the starter from the vehicle by removing the two bolts accessed by removing the air cleaner. installation is the opposite of removal.
how can i proved the starter is bad ? I can't start my car . I assume the starter is bad .
