Question about Fossil Watches
I cant get stopwatch to work - Fossil Watches
  • 2,071 Answers
Stop watch button is malfunctioning it is already stuck up,put a little oil on the stop watch button or "WD 40" or desame kind.Try that so it will works normal again.
Hopes it may help you;
Regards,
VOTIT
Posted on Oct 07, 2008
Removing the beep sound from an avia stopwatch?
If your Avia stopwatch has no option for muting the beeps, there is a very simple way to achieve a semi-permanent mute capability.
1. Using a small screw driver, remove the case back of the stop watch.
2. You will see on the inside of the back panel, a small circle stuck to it. This is the piezo speaker that beeps.
3. Take a small piece of tape and apply it to the speaker. Best choice would be a smooth painter's tape (blue) or electrical tape (black). But thick clear packing tape might work as well. It doesn't need to be a big piece -- just large enough to be in position between the speaker and the metal contact from the stopwatch module.
4. Re-assemble the watch.
5. Test for sound.
Jan 03, 2018 | The Watches
Tag heuer stopwatch
Pull out the middle dialer once then try if that's doesn't work pull it again one will be the chronograph the other will be the stopwatch and if you turn the middle dialer it will change your clock
Apr 27, 2013 | Watches
I havent used my watch for about 3 months and now i cant get the stp watch to work on it? it has been srored in a drawer and is in new condition?
if the watch is still keeping time but the stopwatch wont work then its probable that the watch has two modules inside,one for the normal hour and min hand and a module to run the stop watch.The cell on the stopwatch module will be flat and needs to be changed.Your watch is waterproof so take care who opens it and ask for it tom be re sealed or it wont be waterproof.
If you cant find a local watchmaker see www.rolexrepairs.co.uk where there is a postal repair service within a day or so.
Aug 18, 2010 | Nixon 51 30 Watch
STOP WATCH NOT WORKING
mcdevito75 here, Best Bet, return to the shop that changed the Battery, it may not be the absolute correct battery, Battery could have come slightly loose.
Jul 21, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
How to stop stopwatch on revo rv1006 watch changed the battery but need to stop the stopwatch
Push the upper button once. The stopwatch hand will freeze. Push the bottom button. Stopwatch hand should move to ZERO position. Rate me, please.
Jun 24, 2010 | Watches
How do I zero-out the minute hand of the stopwatch?
Try this: pull out crown to the first click, then push and hold button at 2 o'clock. When the hand is adjusted to the desired time, push the crown back in.
If thi do not work, do the same using the button at 4 o'clock.
Rate me, please.
Mar 26, 2009 | Pulsar by Seiko watch PF3359Men's 100m...
Festina Dashboard watch - Adjusting the hand of the stopwatch
Your watch has quartz movement and stopwatch adjustment by one step (one full second) only. That means you will not be able to adjust stopwatch hand by using pushers on your watch as each push of the pusher will advance stopwatch hand for the full second, not the fifth or the tenth of the second, and the hand will stay slightly off anyway.
This happenened because the IC (integrated circuit) in your watch miscalculated the teeth count on chronograph wheel and stopped one or two teeth past or under the zero point. It doesn't happen very often, but in your case it did and the only solution is to find your nearest watch repair shop and ask for resetting stopwatch hand to zero.
This procedure needs partial disassembling of the watch and quite a great skill as the stopwatch hand must be removed and then refitted with great accuracy. All this needs to be done by very specialized tools as well.
I think this is the only solution of your problem unless you can live with that and just leave it as it is.
Do not forget to rate, please.
Feb 09, 2009 | Festina Dashboard 6719/3 Watch for Men
How do I set up and use the adanac 4000 stopwatch by marathon?
www.marathonwatch.com "Contact Us" They will email you the instructions.
Feb 09, 2009 | Timex T5G811 Marathon Stopwatch
Cant get the stopwatch working
Go to:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Download full user guide.
Jan 07, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
107 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
