Question about Kenmore 44109 / 44102 Side by Side Refrigerator
Kenmore refrigerator Nothing getting cold. Where do I find the relay switch. I believe these have been common items that have gone bad with the Kenmore.
  • 943 Answers
HI thanks for the question. the relay is on the compressor. but are the fan, motors running. if not , then its not the relay. it could be in the defrost cycle. but if fans are running. yes the relay. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 06, 2008
I believe the compressor has gone out. The unit is not getting cold and has thawed on the freezer side and products have warmed on refrigerator side. Question is there anyhting we can do economically or is...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Kenmore Side by Side Refrigerator
My kenmore not get cold both sides
You fan can't circulate because of failure or frost buildup. If its a stuch fan, a little WD-$) and some pliers can free it up. If its frost buildup try this.
It is either a defrost timer or limit switch, That's the little clip on device located on top of one of your freezer coils. This is the most common item to die on many newer refrigerators2_bing.gif. It is also pretty inexpensive, and easy to get from Sears or 1stsource parts. In rare cases your defrost heater may go bad, but I haven't had to replace one in a long while.
Mar 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer
It is either a defrost timer or limit switch, That's the little clip on device located on top of one of your freezer coils. This is the most common item to die on many newer refrigerators. It is also pretty inexpensive, and easy to get from Sears or 1stsource parts. In rare cases your defrost heater may go bad, but I haven't had to replace one in a long while.
Mar 09, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge nor freezer are getting cold.
The over load relays on your compressor have gone bad. Easy way to check is to remove them and shake. If any rattle at all they are bad. Replace the overloads at the compressor. Hope this helps
Jan 31, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Food at bottom of fridge freezes
Bad cold control switch.
The cold control switch should open when the set temperature has been reached. If the control does not open and turn the compressor off, it will continue to run and freeze items in the refrigerator section.
If the control is not closing, the compressor and all fans will stop operating. Check the control for continuity. If you don't feel comfortable checking this yourself, get a repair person out to check it out.
Hope this helps.
Aug 07, 2009 | Kenmore Refrigerators
Starter overload switch
Relay is bad just replace it it is a safety to keep the compressor ok in the event of power surges or failures
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Not cooling
there are 2 common problems with this frig. one is the defrost timer getting stuck in defrost. in this case all lights will work but no fans and no compressor running. the other problem is the relay overload on the side of the compressor but if this is bad the fan inside the freezer will be running. sounds like defrost timer
Nov 20, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Switch relay
are you talking about the switch on the compressor whice is called a relay overload if that is bad try installing a new one on it called a 3 n 1 start kit it is easy to install follow dirictions good luck
May 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 44109 / 44102 Side by Side Refrigerator Logo
185 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
