Question about Sharp Personal Organizer & Spanish/English Translator
How to change time and date in sharp 4400 - Sharp Personal Organizer & Spanish/English Translator
  • 48 Answers
Press menu 3 to enter the entry mode, then press either the right arrow key(next to the green start key) or the # key to scroll to date and time then press start. I'm sure you can finish the rest.
Posted on May 25, 2009
Unable to cancell que on epson 4400 printer
Go to the printer queue on your pc and cancel the printing from there
Aug 16, 2012 | Epson T6138 Matte Black 4400 4800 4880...
HOW CAN I CHANGE MY FAX NUMBER IN A SHARP FO-4400? ITS STILL SHOWING MY OLD ONE
You can get the manual at http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/FaxMachines/Manuals/Archive/fax_man_FO_4400.pdf
Page 24-27 cover the setup of the phone number, date and time.
Press MENU and then 3 Press 0 and then 3 Enter Fax number Press START
Sep 15, 2011 | Sharp FO-4400 Fax
Auto receive not picking up
Due to the age of the Fax (mftr date 2003) and availability of other equipment, we retired the device to our recycling pile!
Aug 26, 2009 | Sharp FO-4400 Fax
SHARP F0-4400 Need to lower baud rate to 9600 on
Don't do it, it will make your machine extremely unreliable.
Fax machines are ANALOG devices and will not work on a DIGITAL phone line.
Jun 26, 2009 | Sharp FO-4400 Fax
CANT GET MY SHARP WIZZARD TO DISPLAY THE CURRENT YEAR
If the pda was made in 2005, it's likely that there is a small watch battery somewhere which saves your settings, date, time, etc.
If this "CMOS battery" needs to be replaced, you're probably losing all of those basic settings whenever you let the main battery lose too much of a charge.
Hopefully, it's easy to access.
Apr 28, 2009 | Sharp Wizard OZ-590A
I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 27, 2009 | Sharp EL-1750PIII Calculator
Sharp FO 4400 full memory after power surge
Try holding down the stop and start keys while turning the power on and see if that clears the problem.
Andrew
Mar 16, 2009 | Sharp FO-4400 Fax
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Feb 17, 2009 | Sharp EL-1801P Calculator
Sharp Personal Organizer & Spanish/English Translator Logo
159 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
