Question about Maytag Kitchen Ranges
My maytag oven's clock won't turn on. It just says "OFF", but there is a lack of a visible on button. The range works fine but I cant bake because I cant set the time let alone a temperature.
  • 750 Answers
Hello roborrob,
Welcome to fixya,
You said, Your Maytag oven's clock won't turn on. It just says "OFF", but there is a lack of a visible on button. The range works fine but I cant bake because I cant set the time let alone a temperature.
What is the model and year of your range?
Try to turn off the rage and then throw the breaker of for 5 minutes and then see if this sresets the system.
How long has this been going on?
Or did it just start ?
And how log have you had this range working fine!
Huuum
Posted on Oct 06, 2008
Maytag electric range model# MERH752CAS oven and stovetop stopped working.
Check the breakers. The range runs on 220v and one of the breakers may have tripped and it is running on 110v. Post back the results.
Feb 10, 2013 | Kitchen Ranges
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
Some Ovens Control Buttons Don't Work - Frigidaire PGLEF385B
although you cannot see damage / the when the buttons do not respond. its possible that membrain is damaged or the eoc ( clock ) is not able to receive signals from the touch pad .. the clock will have to be replaced . list price for clock is 171.00 and includes membrain ( touchpad) .. hope this will help mm
Dec 03, 2009 | Frigidaire FEF376 Electric Kitchen Range
Thermador 30" Dual-Fuel Range 0FF error
I am quoting above because I really need help. "When I push any of the function buttons on the oven console (Timer, Bake, Broil, Clock) the display shows 0FF in red next to the clock. The oven will not turn on and the timer will not work. I can not find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Apr 17, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Mar 23, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Kitchen Ranges Logo
126 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
