The horn won't honk from the inside of car but beeps when alarm is set. Also, the airbag light is on. Been told by a person at VW that it "may be the horn itself or relay of some sort". Can't afford a mechanic while living on a disability payment . . . . any help appreciated.
You have a broken rotating contact under the steering wheel, it is a ribbon that looks like a clock spring, it is called the air bag clock spring contact, anyway replace it and your problem will be fixed, be careful to disarm the airbag before you pull the steering wheel, disconnect the battery for 1 hour and then disconnect the airbag control module before starting any repair.
open the hood and look in the under hood electrical fuse relay center should be a relay that is marked horn or you can pull the fuse marked horn.must likely its the air bag on steering wheel.it coukd be the alarm but you would have to take to shop or get a book to help you, good luck
holdboth the lock and unlosk buttons on your remote simultaneously for about five seconds until the lights flash and horn chirps.that should do it.if not i believe these models used a separate horn for security system.possibly fuse for this horn is bad or the horn itself is bad.to see if this horn works lower drivers window.stand outside vehicle and lock doors with remote.wait about a minute and reach in window and MANUALLY unlock and open door(do not use power door lock button)this should cause the system to activate...horn should beep and headlamps should flash.if horn beeps try my first suggestion.if it doesnt beep and just the head lamps flash check fuses and horn for security system.
My 4Runner did the same thing. What I did was just put a new battery in hook it up and let it honk. Put the key in the ignition and start it and it should stop. It is in alarm mode.
try honking the horn normally with horn button <key must be on> if horn works it is in the programing for comfort and convieniance system if no honk it's just the horn or wiring to horn.
