Question about Nikonos V 35mm Point and Shoot Camera
Do you also cover the IV-A?
When I 'click", I hear two fast clicks. But, sometimes the time between clicks is as much as five/six seconds - in A mode. Camera never been underwater! And little used topside.
abrown007@socal.rr.com Al Brown - thanks.
    Scholar:
  • 185 Answers
Abrown007
open the back cover and fire the shutter a few times towards light. the shutter should open completely with no hesitation. check to see if there is oil on the blades. if so the camera must be cleaned.
if no oil on the blades then the shutter magnets are at fault and it will have to be repaired. you may need to hold the counter lever in to fire the shutter with back opened.
Posted on Dec 14, 2008
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
2006 ford five hundred headlights brighten every 5 seconds
Sound like a bad ground somewhere but it is strange its every five seconds. See if you can hear a relay clicking somewhere under the hood or dash.
Dec 14, 2013 | 2006 Ford Five Hundred
HOW DO YOU PUT REFRIG IN DEFROST MODE WHEN IT HAS ELECTRONIC DEFROST CONTROLLER
You didnt give the make of the ref.; But your solution is here for most all
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, see picture...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. A close up common way *this* version of the Maytag/JennAir control is wired.
Amana also has a version of adaptive defrost, see info sheet for some help on the Amana version. Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A ?¿½d?¿½ in the freezer temperature window and ?¿½F?¿½ in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. ?¿½d?¿½ and ?¿½F?¿½ will be displayed until the defrost cycle is complete. (approx. 8 minutes)
For some Whirlpool refrigerators - some Kenmore refrigerators are made by Whirlpool ( 106.######## )
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
?¿½ If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
?¿½ If the relay clicks two times, check for an open bimetal.
Maytag S-S Refrigerator MSD2756GEW forcing defrost cycle
I replaced my defrost heater two weeks ago, but the frost built back up on the evaporator coils. Replaced the adaptive defrost board with new ( Maytag p/n 6100598 8 ) board. Want to force a defrost cycle to see the heater work, so I shorted the L1 pin to adjacent pin (now called DOOR instead of TEST) for three seconds and nothing happens. Compressor keeps running, fans still going etc. Tried pressing the door switches 5 times in 6 seconds and that doesn't work either. Any hints on how to get the defrost cycle to initiate?
This might help, a copy:
The issue is that some 12002104 ADC boards have been shipped in the 61005988 ADC board box. Do not reorder the board, the 12002104 board will function the same in place of the 61005988, but you must use the forced defrost method for the 12002104. Jumping "L-1" and "door" will not initiate the forced defrost function.
To Initiate Forced Defrost Cycle:
Cycle cold control on and off three times in six seconds. The cold control needs to be left in the closed (call for cooling) position for the defrost system to energize on all platforms. It is not enough to cycle the cold control knob, the contacts must actually open and close (open doors for a period of time if necessary to force the control to call for cooling). In most cases, you can hear the contacts open and close if they are doing so.
To Terminate Forced Defrost Cycle:
Disconnect power for five seconds.
You were right. I cycled the cooling controls three times and it went into a defrost cycle. Thanks.
Aug 08, 2011 | Refrigerators
05 cts when iturn the key the engine does not stat just a click 2 or 3 times the it starts and it does not sound healthy( im from winnipeg minus 25 don't plug car in) when it warms up it does strt fine...
If it's the original battery, it's 12 years old and way beyond it's useful life. If replaced once, the second battery is probably near the end of its life, five to six years
If you're near a Wal-Mart super store, get a new battery installed if the other is old, five to six years They have good prices and top rated batteries by CR. While you're there and if it's -25 (C or F since the scales are concurrent about that point) go to snack shop and warm up with a nice hot cocoa or hot cup of coffee. Sometimes its free in the customer lounge.
Good Luck
Sep 22, 2017 | 2005 Cadillac CTS
Freezer not freezing, refrigerator warm, hear clicking sound
sounds like a bad starting capacitor ... thats about a 2 inch container mounted on or near the compressor .. it will have wires attached ... dont let the compressor keep cycling like that .. it will eventually damage the compressor and the refrigerator will quit working before long anyhow .. there is a little cooling now only because the compressor is successful at starting now an then but that wont last long ...unplug the unit until repairs are done .. move your food to another cooler .. the click you hear is the thermal overload switch shutting off the compressor power when it gets too hot .. the starting capacitors are not expensive and may have plug in electrical connectors that will make replacement easy .. it could be soldered in and that would make it a bit more difficult but usually there is a plug .. there will be numbers stamped on the capacitor .. thats what you need to get a replacement .. or you could remove it and take it with you to a parts supplier .. sometimes there are two capacitors in one container .. both have to be changed at the same time in that case (one for the compressor and one for the fan) ... there will be a part number and a value number .. the value might be something like "16 MFD " at 300VAC that gives you the value of the capacitor (not the phisical size) that example would be "16 micro farads" .. the 300VAC is the voltage rating
the part number gives you the size and mounting configuration as well as the value .. make sure the unit is UNPLUGGED before working on the capacitor .. if you call a refrigerator repairman then it should take him only about 15 min to replace the part if he has an equivalent part with him ... you could give him the model number of your frig and that you suspect the "starting capacitor" before he comes out ..so he can bring one with him ..
Oct 05, 2009 | Whirlpool ED2SHAXM Side by Side...
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Every time I try to play back a video, it goes super fast and I don't know how to slow it down!
Are you sure you have not recorded the video in time-lapse mode? Could be worth checking. Once in the Video setting, you can use the thumb ring to change video mode - one of these modes is normal and one is time lapse (there are five or six others).
Apr 13, 2009 | Canon PowerShot G9 Digital Camera
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Cover open, camera does not turn on.
Completely open lens cover by sliding the lens cover all the way to the right until you hear two clicks. The first click will put the camera into playback mode. The second click will put the camera into shooting mode.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Nikonos V 35mm Point and Shoot Camera Logo
81 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
