Connection problems I can't get connected to the internet without using the ethernet cable
    Problem Solver:
  • 13 Answers
Unless you have a wireless router/access point and a wireless card in your computer, you will need to use the ethernet cable to connect to the internet.
If you do have a wireless router/access point to connect to and a wireless-capable computer, try sticking a pen or the end of a paperclip into a hole on the router marked "Reset" (it might also be unmarked). Hold that button for 30 seconds.
Your router should now be reset to factory defaults. You can now connect wirelessly by choosing the name of your router's manufacturer from the list of available networks. To do that:
Windows XP
  1. Right-click on "My Network Places".
  2. Choose "Properties".
  3. Right-click on "Wireless Network Connection".
  4. Choose "View Available Wireless Networks".
  5. Choose your manufacturer's name from the list that appears.
Windows Vista
  1. Click on the network icon in the lower right of your screen (two computers, one behind another).
  2. Click "Connect to a Network" (it also might be labeled "Connect or Disconnect").
  3. Choose your router manufacturer's name from the list that appears.
Mac OS X
  1. Click on the AirPort menu in the upper right corner (it looks like four "("s on their side).
  2. Choose your router manufacturer's name from the list that appears.
Posted on Oct 07, 2008
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
I reset router....am having problems connecting to internet. I can connect as long as I have the ethernet cable connecting from the computer to the router. When I take out cable from computer, connection...
You need the Ethernet Cable in your Router to be able to connect to the Internet.That is the only way your going to be able to have Internet.It will not work without the Ethernet cable.
Jul 31, 2010 | Linksys WRT400N Router
How can i connect internet to my ps3 without using wifi
all u need is a ethernet cable run it from your modem to the back of your ps3
Apr 18, 2010 | Sony PlayStation 3 40GB System
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
CAN NOT SUCCESSFULLY INSTALL THE INITIAL SETUP.. HELP NEEDS..
Do you have your DSL set up with just the modem connected to one computer? You mentioned that "there is no internet connection problem without router". If you don't have the internet connection working without the router anyway, then how do you expect it to work with the router?
First, you need to make sure that you can plug in one computer to the modem and get an internet connection. This needs to be done with the Verizon Setup CD if you haven't done it already and by connecting your computer to the modem with the USB or Ethernet cable (you can use only one.) I would recommend using the Ethernet cable since this is what you will be using with the router. Once you have the Internet set up with one computer this way, then you can move on to the router.
Disconnect the computer from the modem and actually pull the power plug from the modem. Modems often will not reassign IP addresses when you change what device you plug into them, and thus need to be power cycled. Plug the ethernet cable into the WAN port on the Linksys (and make sure the other end is still connected to the modem) and plug the power cables of both the modem and the router back in.
You should now be able to connect your computer to the router with another ethernet cable (to one of the numbers ports, NOT the WAN port. This is reserved for the modem) and run the setup again.
May 14, 2008 | Linksys Wireless-B Broadband Router Retail...
Trying to get router to work
U can use
USB Ethernet Adapters.Visit:
http://www.ramelectronics.net/network/network-cards/usb-ethernet-adapters/c40000-c43000-c43004-p1.html
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
