Question about HP iPAQ H5455 Pocket PC
HP ipaq rx4240 frozen at the blue start up screen
The hard reset does not help and the computer recognizes it but the HD software does not. I've attempted all the troubleshooting on the HP web site and on my computer. No luck!
  • 7 more comments
  • whitfiep Oct 06, 2008
    A "cold solder" is beyond my expertise. I need a practical solution. Thanks anyway
    It doesn't have any error messages and it does say Formatting PS at the bottom when I hard reset it just like it usually does. It will also give the message Boot 1.00.02 and USB high or full at times when I hard reset it. However it will not move on and load. Prior to this occurring originally I had replaced my battery. Nothing else different though and it had been working. I just hit the power button like usual one day and it didn't complete the load. It's been frozen ever since. Thanks
    Sorry. I'm attempting to do four things at once. I have both Windows XP and Vista and have tried it on both systems using active sync and Windows Mobile. No luck with either one. Troubleshooting tells me there is no problem with the device when I go to the control panel and the usb port. The computer lists it as a HP USB sync device. Hope that helps.
    I still can't get it to do anything. Help anyone?
    What sort of device hardware problem would cause this? It was working fine. Can it just suddenly go haywire and could it have been caused by something I did when I changed the battery? Thanks
    OK I did another hard reset and made sure to hold the buttons down. The blue line progresses to the end of the bar and stops and it says Formatting PS at the bottom. Nothing else. Do you think it will be an expensive fix if I send it in? This thing was not cheap when I bought it and I wonder if it is worth it. Thanks
  • whitfiep Oct 07, 2008
    Does anyone have any more information?
    Actually I did install a Zune program also around the time it quit working. I'll give that a try. Thanks
    I agree with your solution. I've tried everything without success. I think I'll just junk it and try a new one. I have afriend who wants to give me a H5455 but it has a problem with the touchscreen. I think i will start over with a new one. Thanks
  • HP Master
  • 13,433 Answers
You will most likely have to send this to HP for repair, or possibly fixable by updateing the internal firmware.
Posted on Oct 06, 2008
    Genius:
  • 1,124 Answers
Did you install any program on your computer lately?
If your computer recognize the device but your HP program not, seem to be a sotware conflict.
Clean your computer, Uninstall and reinstall the HP software again and be sure you are doing the hard reset correctly in your unit.
    Genius:
  • 3,422 Answers
The only home remedy to fix this problem is a hard reset:
press OK and Rotate Screen buttons together, press reset button with the stylo. Also make sure you are holding the keys down long enough.If you still have the same problem then you will have to get this repaired as the fault is with your device hardware,not a software problem.
Goodluck..
  • HP Master
  • 1,879 Answers
Any error messages ?
xp or vista ?
got it working before ?
anything special happened prior to this issue ?
for the other guy:
cold-solder ?!! "houston, we're having a software issue here"
    Scholar:
  • 116 Answers
Try do ing cold solder on the board.
  • mastermind10 Oct 06, 2008
    its the fault in the hardware of the device which you r using.take it to the chip level repair center and get it repaired as they will check the board of your device.the bios setting in your device.and if necessary they will do a cold soldering.
Hp rx4540.How to access the Boot loader mode?? .My ipaq just displays the hp logo on start up and then just freezes.Ive tried soft and hard reset.Help please
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Mar 11, 2010 | HP iPAQ rx4240 Pocket PC
Won't get through blue HP startup screen.
try taking battery out for 6hours then reinstall and hard rest.
this works on mine. bob
Jul 07, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
Wont work with a windows vista laptop??
you need to install the software that is the interface to the hardware. also depending on how old the hardware is it might not be compatible with vista
Apr 25, 2009 | HP iPAQ rx4240 Pocket PC
Frozen screen
hello :-) i just talked to another person who was having the same problem as you. And guess what?? the same problem happened to me on my IPAQ 4350. It turned out when I would hard reset my IPAQ it asked me to align the screen but it wouldn't move and it would freeze and not let me pass . But I later found out that my screen was damaged and I got a new touch screen installed and my IPAQ works perfect :-). I would recommend for you to do the same and call HP and see if they could install it for you. Thanks :-}
Nov 05, 2007 | HP iPAQ H2210 Pocket PC
Doesn't start up
Hi, Based on your post/description, your iPaq 2210 will not power on. It is possible that your battery is deactivated. To reactivate, plug it to the AC power supply/adaptor, press reset at the back of the unit. Assuming no other problem, the unit will initialize back to default factory settings. It's very likely that all your previous/personal settings, files and applications will be also gone. Good luck and pls post back how things turn up. Kind regards.
Jul 21, 2007 | HP iPAQ H2210 Pocket PC
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
IPAQ 1715 not recognized
All you should need is Activesync. Try the following... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 08, 2005 | HP iPAQ RZ1715 Pocket PC
HP iPAQ H5455 Pocket PC Logo
236 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
