Question about Premiere Ranges SCK3XR Gas Kitchen Range
Oven will not light
The electric igniter is working, and all the burners light, but the oven doesn't seem to be getting gas.
  • 2 more comments
  • jeffmarks418 Oct 07, 2008
    That sounds good, except that there is no gas to light.
    When I turn the oven on, I should be able to smell and hear gas coming from the igniter, as I do with the burners until they lite. I don't smell any gas when I turn the oven on.
    ii
    Now, I need to know about removing the igniter. First, how do I get the broiler drawer all the way out of the oven. Can I still use the burners with the igniter removed, or does the gas remain shut off until I find the part.
  • Anonymous Feb 19, 2009
    model number fgp305kw3 oven worked find for two years then went to put casserole in oven and oven would not light but burners work fine.
  • 943 Answers
Hi thanks for the question. the part that's causing the problem is the bottom igniter. it lights up, but not hot enough to ignite the gas. replace, the igniter. thanks the appliance doc
Posted on Oct 06, 2008
  • john gagnon
    john gagnon Oct 07, 2008
    what did you mean no gas to lite
  • john gagnon
    Hi the oven does not work like that . no gas comes out, till the igniter gets hot enough to light the gas .i would check the igniter.
Unable to locate where o re-light the bake burner on this spectra xl44 oven
Your oven does not use a pilot light it has a electric igniter that comes on when the oven is turned on and that is the most common thing thats wrong with a gas oven when it doesn't heat ..that the electric igniter is defective
GENE
Sep 16, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
The burners are not lighting Frigidaire Gas Range only 8 months
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
On our 6 burner gas coocktop, the right two burners don't light
May 10, 2010 | Thermador SGS36GS Gas Cooktop
The gas oven will not light. gas burners light but oven does not
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
O-defective thermostat
O-defective selector switch
O-defective gas safety valve
O-defective gas valve coils
Sep 20, 2009 | Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Gas Oven
try to move your igniter close to burner or it may be loose
Nov 30, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Premiere Ranges SCK3XR Gas Kitchen Range Logo
466 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
Terry
Terry
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
