Question about Abit KV-80 Motherboard
HDD both IDE or SATA 1 are not recognized
I am having a problem with the HDD being recognized and a brand new KV-80
. HDD#1(brand new Western Digital) connected to IDE and was working fine. Installed WinXP Home w/SP3. Customer took it home and then called me to tell me that when they booted it up, they received the error disk not found. They brought it back and they were right and wrong. I got it to boot but then while playing a card game the system shut down. When I try to reboot it, I recieve disk not found. BIOS does not show a HDD
Things I've done.
Replaced PSU (no change)
Put the HDD#1 as a slave on another computer and it was recognized.
Connected a SATA HDD and it is not recognized.
Any and All help will be appreciated.
Dave
  • christmanrd Oct 07, 2008
    The suggestion of replacing the HDD produced the same results. I have following the other suggestion and then the last resort of replacing the HDD with a new HDD. The results are the same. DISK BOOT FAILURE, IINSERT SYSTEM DISK AND PRESS ENTER. The BIOS is not recognizing the HDD either. I have re-set the CMOS, re-seated the Memory, re-seated the Battery.
    Any other ideas or is this a Motherboard Problem and I need to replace it?
    Dave
    Genius:
  • 1,124 Answers
Unplugg the disk from motherboard and reboot your computer
Shut off the computer, connect the drive again and start up again.
If the problem continue, set the drive on your bios manually.
If after that the problem continue replace the disk.
Posted on Oct 06, 2008
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
I keep getting an error message that states the drive is not recognized. I installed a PETA enhanced IDE drive Western Digital Scorpio 5400rpm 8MB, OEM
Have you tried it on another PC? Check the jumper settings, cables, etc.. Try this youtube video and see if it can help: http://bit.ly/fixHDD
If the HDD is brand new, some Motherboards need to be update (BIOS) firmware to recognize the HDD.
What kind of PC do you have? model, etc..
Mar 08, 2010 | Dell Inspiron 2200 Notebook
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
HDD wont fit!!
Just looked at the details that are stored on fixya, I see the laptop would have a SATA connector, so the new one is IDE? you will have to get a SATA drive and it should fit. well compair the original to the new one, the one with flat connectors fits?
Jun 15, 2009 | Dell Inspiron 1521 Notebook
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
Acer Aspire Hard Drive failure
any laptop Hdd will work as long as you know whether it is SATA or IDE.
The casing around the Hard drive will be different, but can easily be put onto the new drive, but be careful of static and dont drop it
Feb 02, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Abit KV-80 Motherboard Logo
319 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
