When I try accessing my recycle bin or try to go to "Add/Remove Programs" I get an error message from Explorer. Error signature is as follows: AppName-explorer.exe AppVer:6.0.2900.3156 ModVer:1.0.2.5 Offset:000070e1 ModName:mwssrcas.dll HELP!!
    Master:
  • 505 Answers
Scan your computer with Malwarebytes and Superantyspyware which can be downloaded free from the internet. also installed Hijackthis and then remove all the BHO and no name items. Restart the computer and you will not get the error any more
Posted on Oct 07, 2008
Every time i open yahoo messenger error appear on the screen it says "cannot load resource dll"
1.this means that the link to the program is lost.
2. the "dynamic link library" for this particular program is lost or corrupted and needs to be re-installed.
3 Some how you have deleted the link by deleting the program. Check your recycle bin and restore if the recycle bin has not been emptied.
4. Uninstall the Yahoo messenger under the "Control panel" and "Add/ remove programs" then re-install the Yahoo messenger.
Jul 01, 2010 | Computers & Internet
I can't access my yahoo messenger.what should i do?
What exactly is happening when you are attempting to access your Yahoo Messenger?
If it is hanging and not giving you an error message you might try the following:
clear out your C:\WINDOWS\TEMP directory (this is a storage area where files are stored before they are installed). Delete everything in this file, and your problem may be solved completely.
If this does not work, you may also need to clear out your Internet cache (temporary Internet files):
(Internet Explorer)
1. Open Internet Explorer.
2. Click on Tools -> Internet Options.
3a. In IE6 - Click on the 'Delete Files...' button on the Genral Tab
3b. In IE7 - Click on the 'Delete' button under the Browsing History section of the General Tab.
(Mozilla Firefox)
1. Open Firefox.
2. Click on Tools -> Options
3. Click on the Advanced tab -> Network Tab.
4. Click on the 'Clear Now' button under the Cache section.
- Empty your recycle bin
- Run Scandisk
1. Click Start->Programs->Accessories->System Tools
2. Select Scandisk
3. Select your hard drive. If you have more than one, you should scan each drive individually.
4. Click Standard
5. Check Automatically fix errors.
6. Click Start
- Run Defrag
2. Select Disk Defragmenter
3. Select the hard drive you wish to defrag and click ok.
If this still does not work try removing and reinstalling Yahoo.
Depending on your operating system you will need to get to add remove programs from there you will choose the selected program and click uninstall or remove, it may prompt you with some questions just answer them to your preference to continue. Be sure to restart your system if it doe not do it on its own.
I hope this answers your question.
Thank you for visiting FixYa for your solutions.
Susan
PS - Please be sure to leave positive feedback :0)
Apr 14, 2010 | Computers & Internet
When i try to open facebook mindjolt bouncing
why you are getting this issue means because of the internet explorer.
>please go ahead and uninstall the internet explorer 8.0 from the add/remove programs
>restart the computer
>then the internet explorer 7.0 will open by default
>now try to access the facebook and the issue will get fixed.
------------All the best-------------------
Nov 18, 2009 | Microsoft Internet Explorer 8
Error 1721
Try the following regardless of the software as this is the common error message provided by Microsoft. Of course this won't rule out either a corrupt installer or incompatibility's
  1. Disable/Configure any anti-spyware or anti-virus software on your system during installation process. For example: Spybot Search and Destroy Program or Norton Anti-Virus
  2. Check to see if any spyware or adware is installed on your system blocking the completion of install process.
  3. Check to see if you find any unwanted entry in Add/Remove Programs or Internet Explorer - Add/On's section (Tools - Internet Options - Programs -> Manage Add On's). If you found one, remove/disable this entry.
  4. On Windows Vista, disable UAC (User Access Control) feature for your account
Aug 27, 2008 | Microsoft Windows Vista Ultimate Edition
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang. To resolve this issue, use one or more of the following methods. * Empty the Recycle Bin Use the following steps to empty the Recycle Bin: 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Empty Recycle Bin" 3. Tap "Yes" when asked to confirm the file deletion. * Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete". * To make additional space available for the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the slider to the right.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Windows CE device
Sep 14, 2005 | NEC MobilePro 880
Windows CE device
Sep 14, 2005 | NEC MobilePro 750
Windows CE device
Sep 14, 2005 | NEC MobilePro 250e
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
