Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
HI,I have a free stand GAS stove top/oven combo
ml#: 362.75478691
Serial#: 7G2047108
The stove top works, broiler works, but a gas smell is emitted and very slow to warm and cook if bake part of oven is used.
Please help!
Thanks,
Anne
  • swparkerww Oct 08, 2008
    Broiler comes on but the oven bake feature does not
  • 943 Answers
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 08, 2008
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
Oven/Broiler doesn't work. Stove top works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | Tappan TGFS26C Gas Kitchen Range
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Kemore gas range model #790: oven does not get hot, but stove top and broiler both work
Hello- Sounds like lower burner ignitor is bad. Resistance should be more than 4ohms. across ignitor. Parts available locally at app. parts store for 50-75$. Fairly easy to install. - Hope this helps. Thanks- ED
Feb 27, 2010 | Kenmore Kitchen Ranges
I need to change my oven ignitor and I need a diagram to show where it is located. I have a Frigidaire model FGF353BADB. Free standing gas stove/oven.
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Jul 31, 2009 | Frigidaire FGB24S5A Gas Single Oven
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Maytag MGR575qdq gas oven
Replace thermostat in oven and this should fix ya!
(Please rate answer to help keep this site FREE!)
Thank You!
Dec 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
454 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
