Question about Kyocera KM-1510 Copier
Kyocera model km-1810 laser copier error code a400
Cant find any info on this model anywhere , its about 6 or seven years old, is it worth repairing.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kyocera Master
  • 1,362 Answers
Dependds on what the problem is and $ of repair ??????????????
Posted on Oct 07, 2008
  • CheckitRight
    CheckitRight Oct 07, 2008
    Sorry, I did not see that youposted the error code.
    Anyway the problem is with the laser unit that scans the documents and put the image on the drum to print, some techs say they have opened it to clean and it worked, worth a try if it doesn't work now. a new one runs about $ 550 !!!!
MOI BARNI TECHNICIENT
CLIC SUR TOUCHE GOUCHE ET STOP ET TOUCHE VERT AU MEME TONS OK APRE MACHINE C4AFICHE U.000
APRE ENTRE U.20 PRINT ET TOUCHE AUTU MATIQUE APRE TOUCHE PRINT VERT BON CHANCE
Posted on Dec 10, 2009
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
Kyocera 1810 A400 error. What is wrong and how do I fix it?
This error refers to a bad laser unit. The laser is what "etches" your image onto the drum as it transfers to the paper.
This is the cheapest replacement unit I have found for you.
Here
Aug 23, 2011 | Kyocera KM-1510 Copier
DISCULPE REQUIERO SABER EL ERROR A 400 DE MI COPIADORA KYOCERA MITA KM 1505, todo opera casi normal pero me bloquea con ese error a 400
bonjour ,j'ai une photocopieuse kyocera km 1505 et me marque le message erreur A400 ,y a t 'il quelqu'un qui pourrait me dire quesque c'est ce message là je vous remercie d'avance
May 02, 2010 | Kyocera KM-1505 Copier
I need to know what error code A400 means?
a400 is a trouble code for Laser Scanning Unit problem.
Jun 24, 2009 | Kyocera KM-1510 Copier
Keyosera mita km 1505 error A400
A-400 error is due to a bad laser unit. The laser will have to be replaced. They are not cheap...about $400 for a new one or $250 for a rebuilt one.
Apr 28, 2009 | Kyocera Mita KM-2530 Laser Printer
Hello- We have the Kyocera KM 1510 and have an error message A400 coming up on the printer. No functions will work..do you have a suggestion or what would cause this problem. The toner cartridge was just...
Inside the printer, in the laser assembly, the zoom motor is not working anymore. Try to open it, stay clear of the lens, remove the little board with the motor atached to it, open the motor and clean it. Normaly it should run smoothly. i had the same problem, solved it, but now i get the A100 message. Any ideas?
Jan 29, 2009 | Kyocera KM-1510 Copier
I have a machine error
Does your machine have a ADF ( document feeder) on it? IF it does check the connection between the ADF and the machine. Also check the connection between the scanner PWB and the DF drive PWB. These are the 2 boards that let the machine communicate with the ADF. If your machine does not have an ADF, check to make sure that the side covers are closed securely.
Jan 05, 2009 | Kyocera KM-1510 Copier
UNKNOWN CODE
when ap code is coming add toner. when the toner is empty this code displays.
Nov 23, 2008 | Kyocera Mita KMR-1810P Laser Printer
Kyocera KM-1510 Copier Logo
1,706 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
