Question about GE JGBP24 Gas Kitchen Range
MISSING PART OF MY XL44 OVEN
I WANT TO BUY OVEN SAFETY VALVE, DUAL TYPE.
BUT THE PROBLEM IT IS NOT IN MY COUNTRY (YEMEN)
FORM WHERE I CAN BUY IT?
INF:
GE
XL44
MODEL NO.JGBP28BEA2WH
PLEASE HELP.
  • 750 Answers
Hello, ammar738
Welcome to Fixya,
YOU SAID, YOU WANT TO BUY OVEN SAFETY VALVE, DUAL TYPE. BUT THE PROBLEM IT IS NOT IN MY COUNTRY (YEMEN) FORM WHERE I CAN BUY IT? INF: GE XL44 MODEL NO.JGBP28BEA2WH PLEASE HELP.
Below is the web site of one of our sponsors.
I'm pretty sure you can buy it online from them and have them mail or ship it to you. So tell them you pay the shipping.
Give them a try.
Let me know that you are successful
If not I'll find someone who will ship to you. If you have the part number it may help me search if these
people will not ship to you.
Parts house
www.RepairClinic.com
Huuum
Please remember to leave a rating when you are done.
Shookran
Posted on Oct 06, 2008
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
Oven will not start Spectra XL44,Model# JGBP28TED2WW. I already replaced igniter. Thanks Brian
HI. This will be the fault of a failed dual oven safety control valve. This is a new type of valve control device, that dose not rely on a coil controlled assembly. This control valve is damaged, thus, causing the issues you are experiencing. This mechanical failure will require you to replace this control valve, asap.
Part number will be WB19K14
Dec 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
You might try http://www.appliance-parts.com/customers/index.htm which is the CE Sundberg Co. Looks like you are after a WB19K14 which they currently have 4 on hand at their main office in Chicago, plus several at some of their other branches. There is a tab on the web site for persons interested in obtaining parts for export. Hope this helps.
Oct 08, 2008 | GE JGBP28 Gas Kitchen Range
Oven problem.
Only 81/2!! most are only expected to give you 5 good yrs anything else is extras. Your problem may be a defective gas valve (safety valve). Also it may be a defective ignitor - the more likely to go bad (if replacing stuff replace ignitor before safety valve. is there a glowing in the oven? does the flames come on any at all?
Post a response
Regards
Sep 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP24 Gas Kitchen Range Logo
306 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
