Question about Pioneer AVH-P5700DVD Car DVD Player
SWITCHING PAL & NTCS
HOW DO I SWITCH BETWEEN PAL & NTCS
HOW DO I WATCH TV
Posted on Oct 23, 2008
What is this camera?pal or ntcs
Depends which country it was made for? Where was it bought?
Oct 19, 2014 | JVC GR Video Cameras
I have dvr hyundai p80d version 2.1 i change tv projection from ntsc to pal how i put the projection to ntcs
Go into the same menu you used to change it from PAL to NTSC (Using the menue button on the remote control). If you purchased your pd80d, outside of the US, you may not be able to change it.
Mar 19, 2011 | Cameras
Games
it probably have thw wrong reigon code. usa region code is ntcs and the other are pal
Nov 10, 2009 | Video Game Consoles & Games
Changing to NTCS to PAL. I've accidently changed
If you haven't solved this yet, just turn off the system. Press and hold the enter button on the front panel. While holding enter tap the store button a few times until you see "Video: PAL ###" and change this back to "Video: NTSC"
Apr 19, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Can I use Panasonic AG456 camcorder on PAL system ?
le istruzioni che ho scaricato parlano di NTCS sistem
Ma in editring si pu? convertire in pal con power director oppure usando un software di conversione anyconverter pal
Dec 06, 2008 | Panasonic AG-456 Camcorder
Switching between Pal & ntcs
This units display color system is set for NTSC. As far as I can tell you cant change this setting. You can refer to the display information in the manual. Page 111 of 128 at: http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF
Oct 06, 2008 | Pioneer AVH-P5700DVD Car DVD Player
DVD HOME THEATRE SYSTEM
You must change the color system PAL to NTCS or viceversa.
Aug 16, 2008 | Philips PSS110/17 MP3 Player
Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
Jul 29, 2008 | Oritron NPD3117 DVD Player
Playstation 2 pal to ntcs
There should be a way to switch the your T.V. from NTSC to PAL. It should be easy. Yes you can play music on the ps2, if it's on a compatible dvd or cd.
Jul 24, 2008 | Sony PlayStation 2 Slimline Console
Sony cpj-100
Hi there, I'm not clear but you can try to set the video output< pal,secam or ntcs> at setting,NTCS for USA or Canada,Pal for some places in Europe and Secam for France,Portugal ,Greece I think as far as I can remembe,also you can try automatic output but it can't give you nice colors.You may need a converter for tv or pc. I hope this can help you.See you. God may help you.
Feb 28, 2008 | Sony (X39439651) Projector Lamp for CPJ100
Pioneer AVH-P5700DVD Car DVD Player Logo
52 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
