Canon DM-XM2 Mini DV Digital Camcorder
Problem for Canon DM-XM2 Mini DV Digital Camcorder
VHS to DVD: Best Quality?
By Duke - usenet poster
Best Quality of the Analog conversion with consumer products is the most important. Please help me choose:
1. VHS (S-Video or RCA out) -> DV Camcorder (S-VIdeo in (trv950 only?) or mini jack in) -> PC -> DVD
a) Record to miniDV, then through FireWire to PC
b) No recording, Directly to PC. Which SONY model does that?
QUESTION: which quality is the best a) or b)?
2. VHS (S-Video or RCA out) -> DV converter (Dazzle, Pinaccle, etc? Which one is recomended?) -> PC -> DVD
3. VHS (S-Video or RCA out) -> DVD-recorder (I heard that SONY gives the best quality here)
4. New VHS/DVD-recorder -> DVD
Direct DVD conversion with simple menues. (I don't need any special authoring tools, just the basics and best quality video).
Which 1 of these methods gives the best video quality.
More related questions:
5. I have tried 1-a) method, Quality was very soft. can I get better quality than that? Does it depend on the Sony Model?
6. I use Premier Pro with Microsoft DV codec. I heard Pinnacle DV codec is better. Is it true? How do I Install it? are there any others, Better perhaps? Does it really matter?
7. After Premier Pro editing should I use Adobe Encore or TMPGENC for DVD authoring. I have both. So price is not important, quality is the most important.
Thank you for your answers.
Best Solution
posted on May 30, 2006
Very Helpful)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
OK.. let me take a stab at this since I do this quite often for a minimal fee for people.
This is what I do usually and hopefully this will cover some of your questions.
First, you need to start with a decent VCR that will play your VHS. Obviously, you can't control the condition of the VHS tapes but you can try and keep your VCR head clean and I'm assuming you'll be using a 4 head and Hi-Fi VCR.
I usually hook my VCR to my Camcorder which has a passthrough so I can download to my PC via Firewire. I don't record that to MiniDV as that is usually not necessary in my case. My PC is good enough to handle the capture as AVI using Vegas Video (you can use Premiere or the likes) without any dropped frames. There is no gain or loss in quality from directly feeding the signal as pass through via your Camcorder and then Firewire versus recording it as MiniDV first then feed it directly to your PC. At least not that I know of.
I like to capture that as AVI first which is very very close to the lossless uncompressed AVI. So from there, I do all my edits and whatnot then I save that as AVI again and use Procoder (you can use any encoding software but I highly recommend anything that has a 2-pass VBR encoding option) and run that as a 2-pass VBR. Unless the video is relatively short, I usually just do Constant Bit Rate of 8 Mbps since space is not an issue.
Just a few side notes, any real time capture though a H/W, unless is a very high end Avid or Canopus, the quality won't be as good if you use Variable Bit Rate encoding. The reason is that if you use a H/W capture device and you use VBR, there are a lot of quick scene changes from slow action to fast action that the H/W capture card can't forsee and adjust the right bitrate. I'm quite sure that the time it takes for the capture card to adjust this bitrate is extremely quick, I perceive it as still less perfect than if I were to run the AVI through a software encoder that can do a two pass so that the first pass will scan through and detect any scene changes that requires bitrate adjustment and then the second pass to actually do the encoding. Having said that, not every software encoder provides the same result. There are tons of s/w encoders and you need to try them out. Prior to Procoder, I used MainConcept which is bundled with Vegas Video and that did a very good job but Procoder really blows everything away. I do a lot of import car videos and a good encoding is an absolute must as cars move around extremely fast.
I primarily use the Microsoft DV codec and I really can't see any major difference. My videos are extremely sharp and crisp, which may not exactly be a good thing. Most people want the look and feel of actual film so a lot of times I go down to 24 fps and back to 30 as my final render.
If you are doing a lot of tapes and don't want too much hassle of moving footage back and forth (VCR - Camcorder - PC - DVD) then go get yourself a standalone DVD recorder. The same H/W encoder concerns mentioned above applies to these recorders as well.
Hope this helps...
Was this helpful?
Yes
No
Popular Solutions for Canon DM-XM2 Mini DV Digital
Questions and Unsolved Problems for Canon DM-XM2 Mini DV Digital
Do you recommend Canon DM-XM2 Mini DV Digital Camcorder?
Answer
Answer
I need a cover for the microphone on the Cano DM-XM2. Where can I find one and what would the cost... (More)
Answer
Recently the zoom T W buttons both failed to work, so I could not zoom in and out, and then today,... (More)
Answer
when my cannon xm2 is connected to the computer through the 1394 cable its not showing on my desktop... (More)
Answer
Brand new camera, litteraly a few minutes ago. Every tape i try has the same error. They are brand... (More)
Answer
how do I connect the canonCH-190 dual battery charger/ holder to my canon xm2 camera
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon DM-XM2 Mini DV Digital...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
