Question about Lowrance GPS
One side of powersupply is hot and the other side is not. Are both sides suppose to be hot?
  • 153 Answers
One side is hot, the other is ground.
Posted on Oct 07, 2008
Fridgefreezer admrial very hot between doors
It is supposed to be warm it stops them from accumulating moisture. They usually run the hot side of the coils there for that purpose.
Feb 29, 2012 | Admiral 26 cu. ft. Side-By-Side...
Water pouring out of cold water connection the hookup is only connected to the hot water because the steam hookup is suppose work for hot water.... So they say??????!!! Is there suppose to be another hose...
YES YOU NEED TO EITHER PURCHASE A SCREW ON PLUG FOR THE COLD SIDE OR HOOK UP A HOSE FROM A COLD WATER VALVE TO THE COLD SIDE OF YOUR INLET WATER VALVE ON THE WASHER (YOU SHOULD HAVE GOTTEN A HOSE WHEN YOU BOUGHT IT, IF NOT YOU CAN PURCHASE ONE AT YOUR LOCAL HARDWARE STORE OR APPLIANCE PARTS STORE , OR SEARS PARTS DIRECT. LET ME KNOW IF THIS WAS HELPFUL!
Mar 10, 2011 | Frigidaire Washing Machines
Divider between two compartments is hot model 106.59599990 side by side refrigerator
It is supposed to be hot. Approximately 110 degrees.
It prevents condensation between the doors.
The hot gas refrigerant line is routed through the conduit in between the doors.
It is OK.
Sep 06, 2010 | Refrigerators
Overheating ... the rubber edging on the doors is very hot
The rubber edges on the door are suppose to get hot.
some times the fill very hot. many people don't notice this. There is a small mullion heater plased around the doors so that the gasket will not freeze and the door will stick and not open.
Jun 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Grundfos recirculating retro fit hot water out of the cold side
they have it installed wrong it is pulling from the wrong side, it is supposed to pull ot water up to the fixture but then if it stays hot on the cold side they are backwards
May 27, 2009 | Grundfos RCP-96 Recirculation Pump for...
Sizziling red hot coil in rear bottom of freezer (side by side)
That's the defrost heater. The defrost sensor has failed. The freezer has to be taken apart to find the sensor. It is usually round, with a couple of wires going to it.
Apr 27, 2009 | Maytag MSD2454G Side by Side Refrigerator
Lost power to blend door control knob
you have voltage going in the center wire and out the other two on the sides. see function selector switch assembly on right side of diagram.
Please rate as fixya if this helps. good luck.
Mar 21, 2009 | 1999 Ford F150 Regular Cab
GPS Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
