Question about Apple iPod touch
IPOD TOUCH DISABLED.
HOW AM I SUPPOSED TO FIX IT?
  • 1 more comment
  • hanleyj Feb 11, 2009
    my ipod touch is disabled, i need help fixing it. What do i do?
  • mcgrady1588 Feb 26, 2009
    i pod touch disabled and won't uplod to itunes
  • jonathan t Mar 15, 2009
    when i turn on my ipod it doesnt turn on just the sound. y?
Try restoring your iPod.
1. Make sure your iPod is on and connected to iTunes( does not matter if detected or not)
2.Now, hold the home button and sleep/wake button together until the screen blacks out
3. When the screen blacks out, immediately release the sleep/wake button but keep on holding the home button for like 10 seconds maybe or until iTunes says it has detected an iPod in recovery mode and must be restored to be used
4. Now restore it and I hope it turns out better!
Or , option number 2. you try contacting Apple and tell them the problem or go to an Apple store near you and get them to fix it.
Hope this helps!
Posted on May 08, 2009
    Problem Solver:
  • 8 Answers
You need to restore your ipod in itunes
Cheers
Posted on Oct 18, 2008
I need some *****
Posted on Aug 17, 2010
How do i disable my ipod touch?
Posted on Jul 01, 2010
  • 31 Answers
SOURCE: ipod touch disabled
Try turning off your ipod, holding the home button, and plugging it in, while still holding the home button, until a picture of the ipod cable appears pointing to the itunes symbol. this will reset you ipod, and you don't need the passcode to make it usable again.
Posted on Aug 21, 2008
ctf1800
  • 4402 Answers
SOURCE: my ipod touch says that it's disabled, try again
try to turn the ipod off and plug it into your computer. When itunes comes up try seeing if it says ' syncing ' if so it should be good. if that doesnt work
i would suggest you call apple support
Posted on Jun 04, 2009
  • 24 Answers
If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present.
Posted on Jul 29, 2009
  • 21 Answers
SOURCE: ipod touch says its disabled
Use the cable included with your iPod touch to connect the device with your computer. Plug the fat end into your iPod touch and the longer end into your computer.
Posted on Aug 10, 2009
  • 60 Answers
SOURCE: why is my iPod touch disabled for 5009752 minutes
The iPod touch is disabled when the incorrect unlock code is entered too many times. The time the iPod makes you wait increases each time an incorrect unlock code is entered.
There are two ways you should be able to unlock the iPod.
First, connect the iPod to the computer it was last synced with. After iTunes recognizes the iPod, you should be able to enter your unlock code and unlock the iPod.
If the first method doesn't work or you don't remember your unlock code, then do this:
1) Turn the iPod off.
2) Hold down the Home button and connect the iPod to the computer it was last synced with.
3)Release the Home button when the iTunes image appears of the iPod's screen.
4)Wait for iTunes to recognize the iPod and then follow the onscreen directions to restore the iPod.
If neither method works, you will need to contact Apple Customer Support.
Posted on Nov 26, 2009
How do i fix my disabled ipod
Step 1:
If you enter the wrong passcode repeatedly on an iPod Touch, it will display a message that says "iPod is disabled." At first, the iPod will only be disabled for a minute, but if you continue to enter the wrong passcode, it will become disabled for longer periods of time, and finally, you will need to connect it to the computer with which you last synced it. From here, you will need to restore the iPod Touch to factory settings.
Open iTunes. Click "iTunes" in the upper-left corner, then select "Check for Updates" to ensure you have the latest version. Connect your iPod Touch to your computer with the USB 2.0 docking cable. Click your iPod's name under "Devices" on the left-hand side of the iTunes browser. Click the "Summary" tab. Click "Restore." Follow the prompts in the dialog box that appears to finish the restore. Your iPod will return to factory settings. Choose to set up the iPod as a new iPod or from a backup in the screen that appears when the restore is complete.
Mar 29, 2013 | Apple iPod touch
How can I unlock a disabled ipod touch?
Step 1:
The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer. It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen. If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled. To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer. Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window. Click the "Restore" button. If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup. If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings. Wait while iTunes syncs with your iPod Touch and restores the device. iTunes will prompt you when this process is complete.
Feb 10, 2013 | Apple iPod touch
My ipod touch is disabled and i dnt know what to do. i wanna know how to fix it when i turn on my ipod it says ipod disabled connected to itunes
connect your ipod to itunes. and then on the computer, click on your ipod ( a label on the left side) and then click update and then your ipod should be good as new.
Apr 04, 2010 | Apple iPod touch
My apple ipod touch is disabled
try this fix:
http://www.fixya.com/support/r4083816-put_iphone_dfu_mode_restore_3_1_2
.. you'll find there how to restore your iPhone to make it operational again..
Click here for more tips.
Feb 06, 2010 | Apple iPod touch
My ipod touch is disabled for about thirty years and i can only turn it on and off!
Two reasons this is disabled for so long.
1. You have entered the incorrect 'power on' password many, many times.
or
2. You have jailbroken (jailbreak) your iPod Touch and one of the apps you have installed has caused the problem. Possibly a malicious app.
Two ways to fix it. Either wait 4317939 minutes or restore it using iTunes.
The first link below gives details of why a non-jailbroken iPod Touch is disabled.
Second link gives instructions on how to restore your iPod Touch using iTunes.
http://support.apple.com/kb/HT1212
http://docs.info.apple.com/article.html?artnum=305744
Jul 03, 2009 | Apple iPod touch
I dont know what to do please help me my ipod touch is disabled.
press and hold the home and power buttons, when it turns off DO NOT let go of the home button continue holding until it restores itself then connect it to your computer and restore it. unfortunately it will erase everything.
Feb 02, 2009 | Apple iPod touch
Ipod touch disabled
Jun 28, 2008 | Apple iPod touch
Apple iPod touch Logo
1,477 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
