Question about Texas Instruments TI-30XA Calculator
I need to know how to solv problems solving for x with this calculator
(x2+3x)-(x2+2x+3) or 6(t+3)+8-5(t+2)=
  • 43 Answers
There's no way to solve these directly on the TI-30XA.
But the 2 examples you ask about you can do in your head....!
Posted on Dec 31, 2008
How can i write this in my calculator example. 2x=10 the answer is x=5 but how can i put x in the calculator
What you want to do is solve the linear equation 2x=10 to find the value of the unknown x that makes the equality true. Solving an equation usually involves rearranging therms, factors and so on. However your calculator was not designed to handle the solution of equations, no matter how simple they are.
Some Casio scientific calculators can solve some types of equations (polynomials of degree 2 or 3, simultaneous linear equations in up to 3 unknowns). These are the FX-115 ES (Plus) and FX-991 ES (Plus C). Other equivalent models are sold in the world under different names.
Oct 16, 2013 | Casio FX350MS Scientific Calculator
How do I solve for x, 5[(2x+9)/3]=-4(2x+2)?
The Casio Fx300ES does not have an Equation Solver. You must solve by hand (pen and paper). Here is how it goes.
Jan 14, 2012 | Casio fx-300ES Calculator
What ia the sulution of 3y-6x=-3
To find the solution, first find the value of y for each equation.
Then substitue one equation into the other so that you only the x variable left.
Then just solve for x.
Once you have a value for x, then you can easily solve for y.
So for the first equation:
3y - 6x = -3
3y = 6x - 3
y = 2x - 1
Now for the second equation:
2y + 8x = 10
2y = -8x + 10
y = -4x + 5
Since both equations equal y, they also equal each other, therefore:
2x - 1 = -4x + 5
Now just solve for x:
2x + 4x = 5 + 1
6x = 6
Now substitute x=1 into either original equation:
y = 2x - 1
y = 2 (1) - 1
y = 2 - 1
y = 1
Therefore the solution is x=1 and y=1
Good luck, I hope that helps.
Nov 09, 2011 | Texas Instruments TI-84 Plus Silver...
2x^3+6x^2-x=3 I know -3 works for x. But so does -or+ square root of 2 divided by 2. I need the steps so I can see how you get -or+ square root of 2 divided by 2. The question says solve for x.
On most calculators with a solver function, you can specify a starting value for the variable (in this case x) after pressing [Solve] but before pressing the = key.
To get the three solutions, try entering the function, pressing [Solve] then an estimated starting point (say 0.5 or 0.7) then [=]. This should show the +root2/2 result (ie 0.7071067812).
You should not need to enter the function again.
Follow this by pressing [Solve] again, then another estimated starting point (say -0.5 or -0.7) then [=] to get the -root2/2 result.
Similarly, then press [Solve] again, and enter another estimated starting point (say -2) then [=] to get the final solution of -3.
On Casio calculators, the [Solve] function is usually found by pressing [Shift][Calc]. Note that the solver function generally won't return numbers in surd form, only as a decimal value.
Jul 07, 2011 | Office Equipment & Supplies
For instance if I have a problem of 4x+1-x=2x-13+5. how do I enter it in my T E to find wha is X
This calculator does not have a Solve function or a solver. However this example of yours is very simple that you can do it by hand. If you do not mind I will show you how to solve it. Not everything needs a calculator.
You want to solve for x. OK
  1. Start by gathering similar terms 4x-x =3x; -13+5 =-8
  2. Rewrite your equation as 3x+1=2x-8
  3. Make the +1 change side while changing its sign
  4. 4x+1 -1 = 2x-8 -1 or 4x=2x-9
  5. Make +2x on the Right hand side go to the left hand side, changing its sign in the process 4x-2x=-9 or 2x=-9
  6. Divide both members by 2. This gives
  7. x=-9/2 or -4.5 if a decimal result is required.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-30XA Calculator
Solving a linear equation from TI30XS Multiview
Sorry this calculator cannot solve equations. It does not have the program. It does not know how to do those things. However it can calculate. Before you can use the calculator you must prepare all yourself. When you have solved the problem, you ask the calculator to compute the value of what you found.
Let us clean the equation a bit
2(x-4) -5x=-5
Get rid of the parentheses 2(x-4) becomes 2x-2*4=2x-8 .Put that result where it was in equation
2x-8 -5x=-5
Group together the terms that have x in them 2x-5x=-3x
2x-8-5x=-5, becomes -3x-8=-5
You want to isolate the term with x (have it on one side, and the others on the other side) -3x= -5 -(-8)= -5+8 =3.
The equation becomes
-3x=3 Thus -x=3/3=1 and x=-1.
In general you would have obtained x= (some number/some other number) and that is where the calculator would intervene.
Hope it helps.
Sep 11, 2009 | Texas Instruments TI-30XA Calculator
I was ablto to solve for zeros in my ti-89, but know it will not
type: F2,1,12=2x+4,x)
You should see: solve(12=2x+4,x) x=4
you need to make sure that there is an '=' and then you need to type ',x' at the end.
Dec 13, 2008 | Texas Instruments TI-89 Calculator
How do i solve for x on my ti-89?
First to solve a problem, write it like this
Second, for inverse, do this (note the "y=" part)
solve(y=3x^2 -2x+1,x)
The calculator will rewrite the formula as x = ...
Oct 23, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
