Question about Brother MFC-845CW InkJet Printer
My DCP-560CN printer
G'day from Oz
Our home printer has a message which comes up 'No paper fed. Reload paper and then press the Mono (Blue) and Color (Green) buttons. However there is paper in the machine....???
Can someone suggest how to fix this please...
thanks
chris email pipercm@iprimus.com.au
  • Brother Master
  • 5,568 Answers
Do you hear the paper feed motor at all?
If not, either the drive electronics or the motor has failed with the latter being the least likely.
If you do hear it, the pickup roller is probably gotten loaded with paper fiber (there is a difference between cheap papers) or has dried out on its surface. If it seems to be working, take a clean sheet of paper, make a fat line across it about two thirds down from the top with pure alcohol or methanol (don't use 'rubbing alcohol' diluted with water), feed the paper into the machine and stop the paper several times as it is pulled through to try to get the wetted strip stopped on the pickup roller to hoopefully clean it. To get the machine to feed, send it a blank page from any text editor. If it still won't pick up the paper, you will have to gain access to the innards and locate the first roller in the paper path and, if possible, remove it and using a coarse wood file, roughen the roller. Depending on the type of rubber, this can produce tiny 'fingers' of rubber sticking out which will grip the paper better. Pay attention though to turn the roller in the direction of normal operation to produce a surface with 'fingers' that will catch the paper.
Many printers develop that problem with use and it has been serious enough in some older HP models that they designed a special fixture and a small software program that did the same as I suggested with the file. This can be done several times without reducing the roller diameter too far.
Posted on Oct 06, 2008
How to reset unable to clean 50 on dcp-j125
Try to reset Purge, it just might help.
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Clean unable 46 error on dcp 135c brother printer
Jun 03, 2014 | Brother DCP 165C Compact Color Inkjet...
Message comes as unable to clean ... cartridges are brand new no paper jam in the system the model is DCP 340 CW
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 16, 2009 | Brother DCP-340CW All-In-One InkJet...
Brother DCP-560CN unable to print
did any of you three that have the prombelm try going into the files and turnig off all the periously loaded commands ? I bet this is the prombelm, cause the printer only does what it is told and if it is haveing and error message it is beacuse it is tuck in that command of left over printing comands and they haven't been erased yet try and see if this helps and get back to me lala linda
May 28, 2008 | Brother MFC 420CN All-In-One InkJet...
Finding drivers to download for my dcp-350
http://welcome.solutions.brother.com/bsc/public/SearchResult.aspx?reg=us&TXT=dcp-350c&FLG=0&c=us&lang=en
and have a look around there (faq)
Apr 05, 2008 | Brother DCP-350C InkJet Printer
I cant to move my DCP-115 to the maintanance mode
First button is MENU then start b/k copy then 4x arrow-up....
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
Paper Jam showing but no paper in machine
ALicat, please press menu then the blue start mono button. After that 4x the arrow-up(+)button. What error code does the machine display?
Oct 07, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother MFC-845CW InkJet Printer Logo
78 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
