Question about Canon DR-2580C Path-Through Scanner
Blank or blurry left edge of scanned documents
All of a sudden whenever I scan documents there is about an inch on the left side of the page that is left blank or very very light. I have tried cleaning everything, looked for damage from staples, etc. What should I do?
  • 490 Answers
Try scanning a full page (A3) at different levels of contrast and in the Automode also, in color and Mono. Check the output to see if it is software or hardware issue.
S. Mohan
Posted on Mar 18, 2009
When scanning, why does the entire left side of page have a line down it one inch in from txt?
If you are scanning from the ADF - open the scanner cover and clean the narrow glass plate at the left end. It is usually caused by a speck of dirt or white out on the glass.
If you are scanning from the platen (large plate) you may have a faulty point on the scanner bar or a dead light diode. Alternatively you may have the source document in the wrong place and you are getting a page edge mark.
Apr 14, 2016 | Brother MFC-8370DN Laser Multifunction...
Whenever I scan a picture, It's blurry. Canon Mx410
I had the same problem.
My DPI setting was at 25.
I upped it to 600 and the document scanned perfectly.
Jun 04, 2013 | Canon Pixma MX410 All-In-One Printer
When using the automatic document feeder to print,scan, or fax, the finished page displays a thin line about 5-3/8" inches from the left edge of a 8.5x11 paper. When using the flatbed, no line is...
You need to change the mylar strip on the ADF and also you need to clean the narrow strip of glass that the scanner uses for ADF scans. The Mylar strip is found by opening the lid, as you do when you put a document on the glass. On the left side you will see a Mylar sheet that covers a white backing section. There is a latch on the front and back of the Mylar mount that allows it to drop down. There should be spare Mylars in an envelope tucked under right edge of the white backing strip for documents placed on the glass. Just be sure to orient the new strip the same as the old one. The mylar strips can sometimes be cleaned but usually it is better to replace it if you have spares.
Aug 09, 2011 | HP LaserJet 4345mfp Printer
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
I can't scan different document sizes (A3 and A4) in one batch with the Canon 9080C.
IF you are using CapturePerfect 3. version, you can select "Auto detection" for page size, and under 'more' select 'image size' instead of guide plate. Also you may have to select option '1' under user code U10 in case you want to scan pages over 17 inches long. (Press Newfile and Countonly simultaneously, press 'newfile' till you get U10, press 'countonly' and select 1. This will enable scanning upto 1 meter long).
CP3 has "Skip Blank page option", this helps you to automatically delete blank pages on the back side and scan only those with data.
S. Mohan, Chennai, India
Dec 03, 2010 | Canon DR-9080C Path-Through Scanner
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP c7280 scan 2 vertical lines
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899181&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3204785
this fixed it for me
Sep 20, 2009 | HP Scanjet 8250 Flatbed Scanner
Bad Scan Quality Using Brother MFC-7820N Document Feeder
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
Sep 18, 2009 | Brother MFC-7820N Laser Printer
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
Canon DR-2580C Path-Through Scanner Logo
358 people viewed this question
old marine
old marine
