Question about Dell W5300N Laser Printer
Dell all in one printer 922
Hi, wonder if you can help have a message up printhead error, removed & replaced cartridge and also put new one in, any advice, thanks
  • 628 Answers
The printhead is inside the printer. Hp calls it a scanner. It's the laser that "prints" the info on the drum for printing. Usually a printhead error means that you'll have to get it replaced, not a cheap proposition.
Posted on Mar 17, 2009
WHAT TO DO WHEN I HAVE AN ERROR CODE B200. i CANNOT PRINT AS THE MESSAGE IS CONTACT YOUR SERVICE PROVIDER. IS THERE A WAY I CAN FIX IT MYSELF////
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Aug 11, 2017 | The Office Equipment & Supplies
I have an error message B200
Hi Kathleen,
Aug 11, 2017 | Office Equipment & Supplies
My dell v313w printer gives the message that I need to replace cartridges even after I have put in new cartridges
Are you using Dell Series 21,22 ink cartridges?
Try Cleaning the Printhead on Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
Troubleshooting Printhead Problems on the Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 21, 22 black cartridge and then reseat it. I would then take out the color Dell Series 21, 22 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 21, 22 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 21. 22 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 21, 22 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement or a refund.
Rick
Apr 19, 2011 | Dell V313w AllInOne InkJet Printer
Error message: color cartridge missing on a Dell 922
try another cartridge. if that works then you have a bad ink cart, if not, the sensor is bad, replace the printer.
Dec 30, 2008 | Dell 922 All-In-One InkJet Printer
Hi, Even though I have replaced the black cartridge, I continue to get the message that the ink is empty. I would love some guidance!!!!
Hi snascent,
It's possible that you may also need to replace the color ink cartridge. If this is not the case, then the message you're receiving could be due to any of a number of factors:
1) Make sure that you've removed the sticker and transparent tape from the new cartridge before installing it.
2) Make sure that the new cartridge is snapped in securely, and that the lid over it is snapped close.
3) Make sure that the black cartridge is on the left and the color one is on the right (silly as this may seem, it can actually cause problems).
4) If all of these are done and you still get the same message, you might try powering off and back on.
5) If it still doesn't recognize the ink, you might have a clogged print nozzle. To clean the print nozzles, click Start Menu > Programs > Dell Printers > Dell Photo AIO Printer 922 > Dell Printer Solution Center. On the "Maintenance" tab, click "Clean to fix horizontal streaks" - then click "Print."
I hope this helps you - please let me know if you still have problems, or if I can be of any other assistance.
Kind regards,
H2H
Dec 14, 2008 | Dell 922 All-In-One InkJet Printer
Left Cartidge incorrect
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Jul 08, 2008 | Dell 922 All-In-One InkJet Printer
Printer reads RIGHT CARTRIDGE INCORRECT
If you have purchased the cartridges directly from dell , it will be covered under warranty for 2 years for hardware errors and you can call dell on 1800 624 9896 and get the cartridge replaced , even after the replacement of the cartridges if you have the similar issue then its an issue with the printer and needs to be replaced.
Jun 24, 2008 | Dell 922 All-In-One InkJet Printer
New cartridge
Clean the copper contacts of the cart and reset back in the printer and if your getting the same error message please replace the cart with another cart .......
May 13, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Dell W5300N Laser Printer Logo
102 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
