Question about Dynex Computers & Internet
DYNEX 5 PORT ROUTER
WILL NOT CONNECT TO INTERNET FAILED
  • 905 Answers
You may need to set up network settings
Posted on Oct 07, 2008
Can a dynex DX-ESW5 act as a print server?
No. You need a router to set / obtain an IP or connect it directly to the computer RS232 serial port. No network required, but is old school and may be difficult. Specially with MAC. You are better off getting a new router.
Jan 29, 2013 | Dynex Dx-esw5 10/100 Fast Ethernet Switch...
After connecting my Dynex DX-E402 wifi router to my desktop computer and running the Quick Setup on the router website I still cannot connect to the internet nor will my Netflix-ready DVD player connect to...
Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
Nov 03, 2017 | Dynex DX-E402 Router
I have a dynex 8 port gigabit ethernet switch. I see 8 ports but do not see a port to put the incoming ethernet wire. I put it in port 1 and put an outbound in port 2 but cannot connect to the internet.
Hello
Connections should go.Main internet to router,then from router to dynex switch,then to pc or pcs.
There is no main internet ethernet port, as this is just a switch.You need a Router before the dynex switch.
http://dynexproducts.com/cms/documents/DX-GB8PRT_10-1124_QSG_V1_ENG_Final%20Press.pdf
Apr 08, 2011 | Dynex Computers & Internet
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
Nov 08, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Trying to share internet connection
Make sure that the modem is connected to the internet port of the router and the pc should be connected to the numbered ports. Now power cycle the network, turn off the router first then the modem. Wait for 3-5 minutes then turn on the modem and router.
Jun 28, 2009 | Dynex DX-E401 Router
Cannot connect to internet using Dynex Wired Router
First, power down all equipment.
Second, plug in power to modem, let all the lights come on and boot up
Third, plug in the router power and let that boot up and the lights come on
Fourth, Plug in each pc to the ports labeled 1-4
The WAN port should be connected to the Modem also.
Mar 19, 2009 | Dynex 4-Port Ethernet Broadband Router...
Lost connection between switch and hub - LED flashes every 5 secs
You say you have the same problem when you connect the cable directly from router to laptop, so it apparently is not a hub problem. That leaves the router and the cable. You're fortunate in having a working system on the other port. Why not try swapping pieces to see which is the failed piece? For example, what if you swap the ports for the cables? If it's a router problem, then the "bad" cable should work when in the other port. What if you swap cables? That would reveal a bad cable. Finally, swapping computers would show a computer configuration problem, such as the connection not being set to automatic.
Jan 23, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
Can  Dynex 4 Port Router DX-E402 be used to connect internet on a notebook without using cable to notebook?? i.e. Can it be used like a wireless g router??
Unfortunately, the DX-E402 is not a wireless router, so it can not transmit its signal without a physical cable connecting the router to your computer. If you want a wireless router that can also connect to your ISP, check out the Dynex Enhanced Wireless G Router:
http://www.dynexsupport.com/product/?pid=DX-WEGRTR
Nov 28, 2008 | Dynex 4-Port Ethernet Broadband Router...
Cannot use more than 1 computer with my 5 port router
Start with buying a router. The Dx-ESW5 is a 5-port switch, not a router. http://dynexproducts.com/t-faqs_dx_esw5.aspx
You could make it work, but you'd have to assign IP addresses to each of the machines connected to the Internet. For security and a number of other reasons, it's quicker and easier to just grab a router on sale at your local office supply place for $30 bucks or so.
Carl
Nov 11, 2008 | Dynex DX-E401 Router
Dynex ESW5 connecting PC and Mac
after hooking it up only one computer has internet
Apr 13, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
Computers & Internet Logo
101 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
