Question about Saeco Easy Espresso Machine
Saeco Easy My Saeco Easy espressio machine recently started grinding coffee for about 10 secs and then the red light comes on.  No water, no coffee.  Seems like the ground coffee is getting stuck in the little chute that connects to the brew group. Please help.  I had to drink an instant coffee this morning.  It was disgusting.  Woe is me...
  • 1 more comment
  • cbpersel Oct 30, 2008
    Yes, I had the same problem this morning. Looking for a solution. :-)
  • Anonymous Jan 10, 2009
    Exact same problem - coffe grinds BUT nothing comes out. Cleaned out every visible component in case something was clogged. No luck.
  • Anonymous Jan 29, 2009
    Schnorkie again. I ended up taking my machine for repairs. They said it needed a new sensor that tells the machine when it has ground enough coffee. It cost me $100 (ouch) but the machine has worked fine now for 2 months.
    Problem Solver:
  • 14 Answers
I think I have the solution. The "thwok, thwok, thwok" noise is a solenoid opening and then slamming the trap door that dispenses the coffee. Mine had a similar problem.
Upon removing the top, I found that the solenoid, and further that the mount where it attaches to the plastic frame was broken. Basically, the little plastic fin that should hold the lower flange of the solenoid was sheared off. That left the solenoid free to move, and made it impossible to complete the action to move the dispenser trap door.
It looked like there was no easy way to replace that part of the plastic mount, so I epoxied and zip-tied the solenoid into place. It seemed to do the trick. I doubt it will last forever.
Posted on Jan 29, 2009
OK, you can just press the big button again and it should continue the grind and make a cup. If it doesn't, then open the machine and remove the catcher tray, then take out the big grey grinder thingy. Sometimes a load of coffee is stuck in the chute. Wipe it out with a paper towel. Also check the feed tube that fills the grey grinder. Coffee can get stuck if any moisture has entered the grinder.
Posted on Nov 07, 2008
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Hi, I have a Saeco Talea Giro Plus machine and have only used it a few times. Now the alarm light is permanently on, but the machine has enough coffee and water and the drip tray and dregdrawer are empty....
Hi Natasja, try pull out the driptray and dreg draw while the machine is on and wait about 10 secs. When the red light start flashing, put the parts back. The red light should dissappear. Good luck.
Jul 03, 2010 | Saeco Talea Giro Espresso Machine
Red warning light comes on in my saeco vienna deluxe I just aquired this unit and to date have not been able to make a cup of coffee. All the green lights light up and coffee starts grinding but after that...
More than likely your grind is to fine and you are using oily beans (shiney). There is a small knob in the bean hopper. turn it down to the minus side. Turn the big knob to the # 18. If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Jun 03, 2009 | Saeco Easy Espresso Machine
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Red light will not go off and the machine does not work
try letting vinager and water sit in it for a couple of hours then rinse
Dec 16, 2017 | Saeco Easy Machine super automatic...
Red warning light comes on and stops
put a cup under the water spigot and turn the knob to release the pressure
Dec 09, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco easy
Hi Andrew,
Sorry for the delay, i´m on sick-list and have not access to computer regulary.
Make sure you not get any damp into the grinder.
Try to grind little more coarse to see if the machine will grind the beans.
Have a nice day
Oct 17, 2008 | Saeco Easy Espresso Machine
Saeco Easy Espresso Machine Logo
374 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
