Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Opener will not reverse
I have a chamberlain garage door opener. when I press the button to close the door the motor makes a sound then stops and but nothing happens. It looks like it is trying to open it instead of closing. I verified this by removing the chain and saw the gear turns in the direction of openning the door even though the door is already up. I also see an led light blink 5 times and stop then repeats.
Isn't it supposed to reverse direction if already at end of it's travel.
Thanks for your help in advance.
  • Anonymous Oct 06, 2008
    I have the exact same problem with my craftsman garage door opener
  • georgie99999 Jan 20, 2009
    I have the same problem. What is the solution. What part needs to be replace? I dont want to have a serviceman come out. I could buy a new one for less.
  • 504 Answers
FIRST YOU NEED TO RESET THE CHAIN .
Unplug power
Release the door from the opener close the door manually. take the chain loose and slide the traveler down to reengage with the trolley. Plug in power, run the unit with chain off untill it completes a clockwise cycle and stops. reconnect the chain and set tension.
Adjust the chain tension.
If it still moves 6-8 inches and flashes 5 times. the problem is in the rpm sensor.
Full diagnostics are in the owners manual - FREE at
http://help.chamberlain.com/help/en-us/InstructionManuals
Posted on May 29, 2010
When I try to close my garage door --4100 model-- the door travels part way down, then reverses and goes to the up position. I can force it closed by keeping the garage door wall switch continually...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have a bad sensor.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can open with remote, or wall-mounted button, but cannot use remote to close, and have to hold wall button down continuously (unit blinks when button is pressed and released, and stops closing until button...
If the main light is flashing 10 times when the door reverses you have a door sensor problem. Make sure they are pointed at each other and the small light on each one is lit and not flickering. Tweak them if necessary. If you cannot get the small lights to both come on you have bad sensors.
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener closes when closed
Try this: Loosen the chain enough that you can remove it from the sprocket above the motor. Now run the opener until the sprocket turns in the clockwise direction and stops. Reconnect the chain. This will get everything in sync and you will have to tweak the 'up and down limits' a bit to get it just right.
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Why garage doors only closes
Your assist spring may not be adjuster or dammaged causing your motor to stop reverse. or your up stop sensor is jammed or failed in up stop position.
Sep 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener (chain) motor runs in reverse. Trolley slides forward trying to close door, even though it is closed, instead of sliding toward motor to open door. Happened out of the blue - was
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain model 1100 wont close
I WOULD TRY DOWNLOADING THE MANUAL AT http://www.chamberlain-diy.com/pdfdocs/114A1902.PDF
IS THE UNIT STUCK AGAINST THE STOP BOLT ON THE RAIL??
IF IT IS THE INSTRUCTIONS TELL YOU HOW TO RELEASE IT.
HOPE THIS IS HELPFULL
Mar 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
560 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
