Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panisonic projection tv pt-53wx52f
We got this tv at a yard sale,the guy sold it to us for 20.00,he said he couldnt get it to come on,we took it home cleaned the lenses and blew out the dust,it came on and works good,the only thing is when my boyfriend picked it up he dropped,not that hard,and now the vertical is off and cant set the convergence right because the vertical picture is messed up,so we can watch it but everything on both sides and top and bottom are red and green blurred,cant really afford a tv repair man
  • serge1er2003 May 11, 2010
    clarify solution?
  • 41 Answers
There is a mechanical adjustment on the tubes themselves when it was dropped it could have knocked it out of alignment, or the Convergence ICs are bad with is a common problem with CRT projection tvs.
Mechanically adjusting the tubes can be tricky I wouldn't suggest working on it unless you have some kind of experence with tvs. But if you do adjust the red and blue to the green.
Posted on Oct 06, 2008
Convergence problem on panasonic rear projection TV model PT-53WX52F
the PT47WX42 Convergence repair kit from www.tvrepairworld.com also works for your model. The kit contains the ICs, resistors and the CD with instructions.
Sep 21, 2010 | Panasonic Televison & Video
Hello need help on tv set
SHORT is on the 140 volt line--usually the horizontal output transistor is shorted, and there may be a simple reason for this.
Let me know if you are able with help to test the part indicated. I know the best way to work on this set safely and quickly.
I am in San Diego, and my name is Steve.
SD TECH
Jun 04, 2010 | Panasonic PT-53WX52 53" Rear Projection...
Red spot in the middle of screen
yOUR TV HAS A BAD LIGHT EGINE ASSEMBLE. n EED TO REPLACE A NEW LIGHT ENGINE ASSEMBLY.
May 08, 2010 | Hitachi 60V500 60" Rear Projection...
I have a pnasonic pt-53wx52f the tv turns on the screen comes on for about a second and tv shuts off and the led light blinks 3 times any clue what this could be?
Thats the error for convergence shutdown. You can get the repair kit for your model at www.tvrepairworld.com which has the parts and the CD with detailed instructions. the kit for your model is the PT47WX52 as that applies to your model number as well.
Dec 07, 2009 | Televison & Video
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX52F Color blue adjustment
most likely the two convergence Ics need to be replaced. They are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
PANISONIC 51INCH HDTV
From what I understand its the convergance amplifiers. Good luck obtaining a service manual
Jan 16, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
161 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
