Machine over filling even when set on min. simpson enduro 701
  • Washing Mach... Master
  • 19,396 Answers
When the machine is overfilling , it means that there is a problem with the inlet valve (valve not closing) or with the water level switch, that should turn off the valve when water reaches level.
See the suggestion from It's overfilling at repairclinic:
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Oct 06, 2008
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson enduro 751
If your television is leaking, I suggest throwing it away.
Oct 23, 2013 | Televison & Video
Remove_washing_machine_timer
Remove back panel top.There should be 4 screws holding in the timer.Also the knob may have a small allen key screw holding it on.
Oct 27, 2011 | Washing Machines
SImpson Enduro 701 - motor going slow
u must check capasitor usually so good luck
Nov 20, 2010 | Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Locating the fusebox
The breaker box is located on the wall of your house. There is not a fuse in this machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Washing Machines
Simpson enduro 701 very slow to fill and timer sticks
Hi my name is joyce, sounds like you have trash in you water filter that is in your water line that comes in your machine in the back of washer, this may be the cause for the slow water and the timer will cause the machine not to advance to the next cycle, if you would like I will help to find a service techincian.
Joyce
Feb 06, 2009 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
379 people viewed this question
Top Washing Machines Experts
