I have a laptop a iPhone and disgo 8000 tablet can not connect any of them to the router
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
kindly rate this post, thanks.
SOURCE: How do I connect my wireless laptop to my Belkin
First you will need to check the wireless settings of the router. Is there any computer connected to the router or any computer online using the router ? If not then you will need to connect a computer to the router with the cable. open the set up page of the router. check the wireless settings of the router.
Once you get all the settings of the network, you will need to connect to the wireless network.
Connecting to the network will depend on your computer operating system.
Click here for more information about the router and networks
We are
sorry to hear that the device is freezing and not working as expected.
Please
try the following which may help to resolve the issue.
1) Ensure that the Video/Image files you are trying to view are compatible with
the tablet. Compatible files are located on the packaging and in the User
Manual. You can also locate this information on the website, mydisgo.com
2) If you have not already done so, we would advise that you update the device
to version 2.3. The update procedure can be found at the following page; tinyurl.com/8000update
3) If the Gallery app only freezes when accessing files on the SD card (and
not internal memory), please try using the alternative memory card slot or test
using a different memory card.
I do hope this helps to resolve the issue.
If you require any further assistance, please do not hesitate to contact us at
mydisgo.com/support
Thanks,
mydisgo.com
