Question about Microsoft Windows 2000 Professional for PC
Fonts How do i install new fonts in win2000?
    Problem Solver:
  • 13 Answers
I assume you already have fonts you want to install. If not, you'll need to buy what you want first from somewhere like fonts.com.
  1. Open "My Computer"
  2. Open "C:"
  3. Open "WINDOWS"
  4. Find the Fonts folder, but don't open it.
  5. Drag the font(s) you want to install to the fonts folder.
You might need to restart programs you have open for the new font(s) to appear in the fonts menu.
Posted on Oct 07, 2008
How can I put hyperfont on a new computer when I don't have the disks?
You don't need the disks. Here ya go-
1st get the font you need downloaded, of course. Tons of sites have them free. To install a font
  1. Open Fonts by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Fonts.
  2. Click File, and then click Install New Font.
    If you don't see the File menu, press ALT.
  3. In the Add Fonts dialog box, under Drives, click the drive where the font that you want to install is located.
  4. Under Folders, double-click the folder containing the fonts that you want to add.
  5. Under List of fonts, click the font that you want to add, and then click Install.
To uninstall a font
  2. Click the font that you want to uninstall. To select more than one font at a time, press and hold down CTRL while you click each font.
  3. On the File menu, click Delete.
It works easy! :) In fact I just installed a font that way about 20 minutes ago.
It works just great
May 15, 2014 | Singer Futura Hyperfont
Tip
How To Remove and Install a MAP Sensor for Your 1988 Dodge Aries
REMOVAL & INSTALLATION
Chrysler Electronic Fuel Injection (EFI), Multi-point Fuel Injection (MFI) and Eagle Throttle Body Fuel Injection (TBI) Systems
  1. Disconnect the negative battery cable.
  2. Unplug the electrical connector from the sensor.
  3. If so equipped, disconnect the vacuum hose from the sensor.
  4. Remove the MAP sensor mounting fasteners.
  5. Remove the sensor from the vehicle.
To install:
  1. Install the MAP sensor into its position and secure in place with the mounting screws. Tighten the screws until snug.
  2. Connect the vacuum hose, if so equipped.
  3. Plug the electrical connector back into the sensor. Make certain that the connector is clean and snug fitting.
  4. Connect the battery cable.
on Nov 22, 2011 | 1988 Dodge Aries
Tip
NOW INSTALL FONTS ON N95 8GB 1) Install FontRouter (Fontrouter...
1) Install FontRouter (Fontrouter LT+FontrouterMan)in your memory card, or mass storage in N95 8Gb
2) using the x-plore app, make a folder in phone memory (C:/) named fonts
3) Move the fontrouter.ini and paste in c:\data\fonts
4) edit the fontrouter.ini file with x-plore like this:-
search at:
Extra font files to be loaded
ExtraFontFile=\Data\Fonts\*.*
and change it to
;Extra font files to be loaded
ExtraFontFile=C:\Data\Fonts\*.*
exit and save the file
5) Copy your *.ttf font to c:\data\fonts
6) restart the phone, and there's your new font!
if you afterwards want to change your font
edit the fontrouter.ini file again and change
Enable=1 to 0
restart and change the fonts, then Enable again to 1 and restart and enjoy the new look of the interface.
on May 09, 2010 | Cell Phones
How do I enlarge my font?
Depends on the service you use. attaching two screen caps that should help you.
Gmail
Hotmail
Aug 21, 2013 | Computers & Internet
Hi. How am I supposed to install new fonts under Windows XP Professional?
Glad to help YOU!
If you want to install new fonts you have to follow these steps:
1. put all your font you would like to install into a file (just do in C:\ a new folder named 123 or the way you like) because it will be much easier;
2. go START > CONTROL PANEL;
3. double-click on FONTS icon;
4. once the window appeared fo FILE > INSTALL NEW FONTS and BROWSE to the folder you have put all your new fonts;
5. click OK and let Windows XP to install all your fonts.
It's done!
GOOD LUCK!
My best wishes!
Mar 13, 2011 | Computers & Internet
How to install fonts
Control panel / Fonts/ right click on the white are in the font box and Install new fonts
Or select all the fonts you want, Copy and paste them into the fonts folder
Feb 12, 2011 | Computers & Internet
Konica minolta di 1611, di 2011 driver windows 7 32 bit. konica minolta di 1611, di 2011 driver windows 7 64 bit pozdrawiam Jarek
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Feb 10, 2011 | Konica Minolta Di2011
My pc have no audio after installing win2000
double check that you installed the sound card drivers and that they are installed correctly.
They are available on the cd that came with the motherboard
Or from INTEL
Note these are the XP PRO drivers but should be suitable for win2000
If you get any unsigned driver errors ignore them.
Aug 21, 2009 | Intel D945GCL Motherboard
How to repair workstation, os are win2000 pro in workstation
do you want to reactivate the win220 pro installation on the harddisk which now you cannot access?
insert win xp pro install cd and run the repair process
or
if you have partioned the harddisk, simply do a new install on another partition, mark this active and now you should be able to boot up and access the old installation.
copy the non-microsoft programs plus personal data (everything that is not in the windows folder) to the new installation,
then run every single program from the new installation
good luck
Apr 18, 2009 | Computers & Internet
Unable to load post script fonts in windows-xp
Well postscript fonts are vector outline fonts, so they contain instructions about the building of their outlines and curves and such. Hence two files are required to use a postscript font under Windows.
As to how to install these fonts, well
  1. Click Start | Settings | Control Panel.
  2. Double-click on the Fonts folder.
  3. Choose File | Install New Font.
  4. In the Folders menu, navigate to the folder containing the fonts that you wish to install. A list of available fonts will appear in the List of Fonts window.
  5. Click on the font you wish to install or use the "Select All" button to install all fonts in the List of Fonts.
  6. Click on OK.
Please keep in mind:
  1. If you are installing fonts from a CD be sure the 'Add without copying files' box is NOT checked; unless the fonts are on a located somewhere (such as a network) which you will have access to at all times.
  2. Postscript fonts have two files: PFB (printer font binary has outlines that control how the font looks) and PFM (printer font metrics has information about font spacing). Be sure you have both font files.
  3. If you currently have or previously had Adobe Type Manager Deluxe 4.0, 4.1, or 4.1.1 installed you may need the Adobe Deluxe Updater in order to properly use your Postscript fonts under Windows XP. Get it from Adobe.
Hope this helped. Let me know and if yes please rate me:)
Feb 15, 2009 | Adobe Computers & Internet
Microsoft Windows 2000 Professional for PC Logo
120 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
