Need a singer part for a furance - Heating & Cooling
  • 182 Answers
Good luck....singer hasnt been made for a long time
Posted on Oct 07, 2008
When furance kicks onafter a while the furnace stops working the range hood and the refigerater. after a while its starts working again.
It is difficult trying to understand what you are trying to convey to me. If you live in an older house, this may be the problem. Your furance, refigerator and range hood may all be on the same circuit. Your furance should have a dedicated circuit, nothing else on it. The refigerator should be on a dedicated circuit also, the range hood can be on a circuit with other devices. To find out what is on a curcuit, go to the panel and find the circuit that powers the fridge, have someone watch to see when the light goes off in the fridge, that will be the fridge circuit. Now check and see if anything else is off, eg. if the range hood doesn't work, then it is on the same circuit. If the furance fan will not operate then it is also on the same circuit. Do the same thing with the furance circuit, turn if off at the panel and see what else does not work.
Remember, the furance and the refigerator need to each have their own dedicated circuit.
Feb 21, 2015 | 2002 Bounder 39r
Why does my furance not turn on when the pilot lite is lit?
Apparently it is not calling for heat. The thermostat needs to close. If it is wired correctly and the stat closes and it still does not start something is bad in the control section. You need to get a tech to help you. Randomly jumping wires is asking for a disaster.
Jan 11, 2015 | Heating & Cooling
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
HEATER TURNS ON AND RUNS THEN GOES OFF BECAUSE OF THE ROLL OUT LIMIT. tHE BURNER IS IS FLAMING OUT OFF THE BOX.
The furance needs to be clecned. Is the furance in the sdame roomas a clothes dryer. Lent can plug up the furances burrner tubes. With a shop vac switched to the blower side blow out the tubes and cleran the unit. Be careful not to touch the hot surface igitor while cleaning. These will crack easily.
Feb 13, 2011 | Goodman GMS90703BXA Heater
AC IS TURNING ON BY IT SELF AFTER I SWITICH IT OFF, HOW TO SOLVE THIS PROBLEM
Sounds like a problem with the furances circuit board. With the furance powered off, disconnect the two wires at the circuit boards thermostat terminal strip. These are probably red and white wires connected to the "Y" and "C" thermostat terminal strip on the circuit board. These two wires send 24 volts to the outside A.C. condenser unit when the thermstat is se tinto the cooling mode. With the thermostst in the "off: postion measure across the "Y" & "C" terminals at the furances thermostat terminal strip. If you have voltaged than either the board or thermostst has failed. The next step to determine which has failed is this. Disconnect all the thermostat wires at the furance. To check the heating circuit jumper across the "R" & "W" terminals, the furance should fire off for the heating circuit and run non stop beacause the thermostat is no longer controlling it and is isolated from the furance. Now remove the jumper and jumper across the "R" &"Y" terminals, the blower should run at your furance for the cooling mode and you should have 24 volts across the "Y" & "C" terminals for the outside A.C. condenser compresor contactor.Next check for blower operation by jumpering across the "R" & "G" terminals. If everything checks outs than the thermostst is the problem. Tou may also want to check the control wiring at the thermostts , furance & out side condenser unit. If the wiring has connnected somewhwre between these points or at the terminal connection this may also be bring on the A.C. when the thermostat is in the "off position.
Feb 13, 2011 | Hitachi Heating & Cooling
I have a Rheem heat pump and a Honeywell thermostat. I let my air filters get too dirty, and they restricted the air flow so the system shut off. I have replaced the air filters but the upstairs doesn't...
You may need to replace the furances high limit switch. This is located abvove the burrners with the top frot door off. It has two wires going into it. The furance probably was cycling on this switch which automatically resets it self. The thermal dics wears out and starts to trip at lower temperatures. You can temporally jump across the switch and check the furances opreration but do not leave this switch jumperd because it is a safty.
Feb 06, 2011 | Honeywell Heating & Cooling
Will not send water through the water solenoid valve and blows fuses in the furnace
Is this a small 3 or 5 amp fuse it is blowing at the furance. My assumption it is. If this fuse is blowing right away, then this is a direct short. The solinoid valve needs to be replaced. The valve has a direct ground to casing short. Replace the valve and the furance will not blow fuses anymore.
Jan 24, 2011 | Aprilaire 550 Humidifier
Weather King Furance
Hi Cableman. Any 24-36" thermocouple wll work and can be found at your local hardware store.
Hope this helps,
RepairUSA
Nov 05, 2007 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
