Question about Sony KP-51HW40 51" Rear Projection Television
Green and red lines on tv - Sony KP-51HW40 51" Rear Projection Television
  • pistolpete10 Mar 03, 2009
    My TV is doing the same thing.How do you adjust the screen voltage?
  • Sunny Valiplackal May 11, 2010
    Is this green and red lights how you can describe?Is it retrace line like curve shape?Put the tv unit in to Video1or 2 mode and check..
    If it is a retarce line you can adjust screen voltage.
Red light on the screen with faded pictures then sreen goes blank
Posted on Mar 02, 2009
  • 41 Answers
What kind of projection tv are we talking about a lamp based unit? or a CRT based one? If it is a lamp based one then you could have a dirty light engine which is expensive to replace. If it is a CRT based one you could have bad convergence IC or one of you tubes is in overdrive and the screen voltage needs to be adjusted.
Posted on Oct 06, 2008
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
Lg 55lv6300 has red and green vertical lines help
On other panel TV's this is known as a convergence problem. You have to get experienced help costing about $150 or do it yourself. TV's that age have this issue, and you have to open the Tv and find the voltage/convergence box with three screws on it. It usually has blue, green and red adjustment screws, with red on the right. So go for the green and red and adjust until the issue goes away.
Jan 25, 2015 | LG Televison & Video
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
The TV has red and green lines, I touched the
you willl need an LCD panel replaced the buzzing sound you hear is the broken floresent bulbs arching
Nov 30, 2009 | Vizio VW37L 37 in. LCD TV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Red, bule, green lines do not line up together.
why is my projection tv screwed up on the left side with the color red only i tried to center it and it won't go any further.
Sep 05, 2008 | Televison & Video
Shut-Off Problems with Philips 28ps6515/05
Green Screen with some lines lines are called retrace lines. it is due to maybe dry soldered or no green drive signal. This problem can be fixed by complete soldering in crt board. 1 green video supply absent 2 loose contact in green skt in crt board 3 crt board loose 4 no green drive signal.
Sep 15, 2007 | Philips 32PT6441/37 32" TV
Sony KP-51HW40 51" Rear Projection Television Logo
504 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
