Question about Car Audio & Video
I have a 1996 Chevrolet Cavalier that recently had the alternator replaced. This, therefore, activated the Theftlock device in the stereo. Being that I bought the car second-hand I do not have the code to unlock it. Is there any way to reset the device and have a working stereo?
    Problem Solver:
  • 13 Answers
I think you might have to go right to a gm dealer to have this one fixed, i wish i could help more but my cav already had the factory stereo removed by the time i got it, try checking all over the stereo for a reset button, you never know
Posted on Oct 07, 2008
I got a 1996 chevy cavalier bought new battery and alternator but when u take the jump box off it dies its acting like its not charging battery lights on and dies immediately.
Make dure you installed the alternator cortectly. If do, you were probably sold a bad alternator. Take the alternator to the parts store you bought it at. The will.test it and refund your money, or replace it.
Mar 08, 2015 | 1996 Chevrolet Cavalier
Did you mean: i have a 1999 chevy cavalier with theftlock system i detached the battery before i knew i needed to turn off the theftlock. now my theft light is on solid not flashing can someone please
Turn the key to on, but don't attempt to start. Wait 10 minutes with key in this position, and light should go out. Turn key to off position. Try to start.
Aug 30, 2014 | 1999 Chevrolet Cavalier
Chevrolet S10 Pickup Radio Loss of Power
You must buy that code to activate the radio again. You may be able to get it here: Can find your factory car stereo radio code We can help
Jun 15, 2017 | Cars & Trucks
What year alternator will fit 2000 cavalier
The alternator for the 2.2 engine fits 1996 - 2002 models.
Aug 23, 2012 | 2000 Chevrolet Cavalier
2008 chevrolet HHR radio unlock code
sorry the dealers have the codes and seems they are the only ones that can unlock this
Feb 05, 2011 | 2008 Chevrolet Hhr
I have a 1996 chevy cavalier and I am trying to find a free wiring diagram for the audio system. The person who had this car before me messed it all up and I need to figure out what is supposed to go...
1996 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
i know u said u want a pic but you should b e able to do it from this
pls rate
Aug 16, 2010 | 1996 Chevrolet Cavalier
1996 chevy cavalier alternator replacemant
There usually not hard to replace. Take off belt, disconnect connector and there should be a nut hold a wire on, take that off then it should only be 2 or 3 bolts holding it in place.
Aug 12, 2010 | 1996 Chevrolet Cavalier
How do you replace the ignition switch for 1996 chevrolet cavalier?
Caution:On models with a Delco Loc 2 or Theftlock audio system be sure the lockout feature is turned off before proceeding
  • Disable the airbag system
  • Remove the tilt lever if equipped
  • Remove the upper and lower steering column covers
Ignition Switch
  • Remove the ignition switch retaining screws
  • Detach the ignition switch from the steering column housing assembly and unplug the electrical connectors
Key Lock Cylinder
  • Turn the key to the run postion
  • Depress the lock button and remove the key lock cylinder
Nov 02, 2009 | 1997 Chevrolet Cavalier
Everything turns on when key is turned, but engine doesnt turn, starter doesnt click, nothing...just recently replaced starter and alternator and nuetral switch (its a manual)..could it be the solenoid?
If you have verified that the battery has 12volts, and there is power 12V at the trigger wire on the solenoid with the key turned to start, likely the solenoid is bad...I'd question this though because the solenoid comes with the starter and therefore should be new. (defective?) If there's no power there, re-check what you replaced and also ignition switch.
Sep 10, 2009 | 1992 Chevrolet Cavalier
Car won't start. Already replaced battery and
Replace the starter relay,It is located in the fuse box under the hood
Jul 30, 2009 | 1996 Chevrolet Cavalier
Car Audio & Video Logo
120 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
