As soon as i let off gas the heat or air kind of dims out a little bit.and if i hit the brakes the car dies almost instantly.....last nite when i let it sit and idle when i hit the brakes it made kind of a growling noise..i have no idea wat the problem is can someone please help me...i have already replaced the mass air sensor because someone told me this was the issue..but it did not work! ????any ideas
Fuel filter could be plugged
Hi is maybe a liitle hard to asmwer with out having car to check sensor readings.
But i will help the best i can .Do you have a scanner that you can live data on?
Youll need to check you iac reading that is your idle air control .The growing
you heard was it like a hissing from under dash near brake pedal? That maybe your brake booser.If not where is noise coming from? Also when coming to stop and car trys to die if you hold brake and give gas does it stay running or die
if so check your fuel press at idle should be 38-45 psi maybe fuel pump
When i'm stopped at a light or sign my cars rpm's go down and my car shakes and sometimes either acts like it wants to die or just dies
