Question about Minolta Office Equipment & Supplies
I have a Minolta Dialta Color CF 5001. It begins to start up as usual, then shuts down and displays the following error code: SC29-12
  • Minolta Master
  • 6,005 Answers
Magenta drum charge corona wire is not working open the center pull out the magenta charge corona unit you should see four of them each has a small black handle, push down and pull out then re-seat also ensure the screw at the top of the entire image section is screw ed in.. Or you may have a bad High Voltage unit
Posted on Nov 22, 2015
Kevin Hayes
  • 167 Answers
SOURCE: how do i get drivers for minolta dialtadi350
http://help.bt.konicaminolta.ca/
Posted on May 27, 2008
  • 300 Answers
SOURCE: Hello, Our Minolta Dialta Colour Copier/Printer
C0208: PC Drum Charge Corona malfunction. The SCD signal is detected for a continuous 0.7-sec. period while the PC Drum Charge Corona is being energized.
Relevant Electrical Parts - Image Units C/M/Y/Bk, High Voltage Unit (PC Drum CH.) HV1 IO Board (PWB-IO)
Steps (in this order) - Check the Image unit contacts and correct
or clean as necessary.
Check the HV1 contacts and
correct or clean as necessary
Change Image Unit.
Change HV1.
Change PWB-IO
Posted on Aug 13, 2008
jqsababa967
  • 145 Answers
SOURCE: minolta dialta di181 c1300 error
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Posted on Oct 21, 2008
SOURCE: minolta dialta Di450 Error message C-143E
The Document Feeder has only 1 Malfunction code for any problem with it.
If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it.
The unit was prone to this false malfunction code.
If it returns very often, then get an engineer to have a look at it.
Posted on Jun 12, 2009
kamal1984
  • 1383 Answers
SOURCE: I need driver for Windows xp for Minolta Dialta Di350
click here
you can downlaod install in computer
Thanks please let me know.
Posted on Jul 27, 2009
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
I have an error C0094 what does it mean
You have Minolta dialta CF 3102
The C0094 code -2nd transfer roller separation.Clean using vacuum cleaner the transfer unit and the electrical contacts.
Feb 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Cob08 error
If your copier is Dialta 250 reset the malfunction code.
Push the warm restart switch located on the right side to control panel in area of display contrast knob(hole) and enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screenis being displayed.Select the trouble reset and touch exit.
Feb 11, 2013 | Minolta DiALTA Di250 All-In-One Laser...
Minolta Di183 display shows 88
1 Call the Utility Mode to the Display.
❍ Calling the Utility Mode to the Display (p.7-1)
2 Making sure that “U--” appears on
the Display, enter “5” from the 10-
Key Pad.
3 Press the [Start] key.
Enter the 6-digit administrator
number from the 10-Key Pad.
? Do you know how to enter the
administrator number?
➜ Enter the six digits successively.
? Do you want to correct a wrong
number just entered?
➜ Press the [Clear] key and then
enter the correct number.
5 Press the [Start] key.
6 Check that “Ad-” appears on the
Display.
7
Enter the code assigned to the
desired subfunction from the 10-
Key Pad.
? Do you know the code for Copy
Track?
➜ To select Copy Track, enter “1.”
? Do you know the code for Disable Auto Shut OFF?
➜ To select Disable Auto Shut OFF, enter “2.”
8 Press the [Start] key.
GO to Konicaminolta US website down load a operators manual free
Jan 26, 2009 | Minolta DiALTA Di183 Copier
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Code erreur
CAUSE: Adjustment mode 11 is not set to correct value.
SOLUTION: To set Adjustment mode 11 to proper value, perform the following:
1. Enter Tech Rep mode (Counter, Stop, 0, 0, Stop, 0, 1).
2. Press Stop and then Start. AJ- will display.
3. Enter 11 from the keypad.
4. Press Start. Current value will display.
5. Press Clear.
6. Enter a value of 1 from the keypad.
7. Press Start to save the setting.
8. Press Auto Reset to exit Adjustment Mode.
HOPE THAT HELP
Oct 20, 2008 | Konica Minolta DiALTA Di183F Copier
Neosca63
Subject:
C0030 code is displayed and will not reset. The C0030 is referenced to the developer drive motor for the 4 developer units. developr motor is binding
hope that helps
Jul 04, 2008 | Konica Minolta DiALTA CF910 Copier
Minolta Di351 Dialta
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
Jun 10, 2008 | Konica Minolta DiALTA Di200 Copier
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
