Question about X2Gen MG19MY 19" LCD Monitor
X2GEN MW19U Does Not Power On
I bought this LCD from Ebay and it won't power. The screen just stays black and there's no light anywhere that could show there's any power. I used the power adapter on my speakers and it could power them so i feel the adapter is ok. I opened the monitor and couldn't find any burns. I'm not really an electronic person but am willing to try out ways to solve the problems. Any ideas on how to troubleshoot or solve this problem will be greatly appreciated.
  • njiat Oct 16, 2008
    Thank you for effort to help. I bought a digital multimeter but couldn't locate the protection element. I'm an absolute newbie in electronics although i was pretty good in physics in school. I located a power element (don't know exactly how to call it!) labelled AP1506. It has five pins. I looked up it's datasheet on the internet and measured the Vcc (Vin) against ground with the multimeter and got 6,33V. But the power adapter is supposed to supply 12V. When i measured the voltage at the power adapter itself when not connected to the monitor, it gives 12V. So i went and bought a different power adapter and low and behold the monitor powered up and is now working.
    PS: On the PCB i actually saw 2 blue components with only 2 leads on each, but they were labelled C12 and C17 respectively, so i thought they were capaciors and didn't touch them. I guess i was just lucky with the power cord.
  • pappasmurftg Oct 16, 2008
    XGEN, started out flashing from on to off, then went out altogether.
  • 905 Answers
You will need a multimeter to check, there is a proteection component that may look like a transistor( but only 2 leads on it) or what might look like a small blue capacitor. also the diodes at the power circut need to be checked. also be sure that solder conections are secure in the power circut
Posted on Oct 06, 2008
  • jason Oct 16, 2008
    glad you found the power problem!
What can i do?
Bad capacitor on the power board, Matt. Search Ebay for the replacement parts.
Jun 21, 2014 | X2Gen "MV17FU LCD Monitor 17"" Television"
X2gen mw19u monitor is off but the ''no signal'' light keeps flashing on and off. When I power up the computer, it continues to flash on and off. You can see that the computer is powering on and going...
Hi Steven,
You are getting "No Signal", indicates that CPU is working fine. Check with another monitor or desktop, if it is working gateway monitor is in risk. I recommend you to check with Gateway technician.
Jun 14, 2010 | Computers & Internet
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
X2gen MW19U Monitor Black screen but sounds like it is cycling
The monitor is on protection.
Test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Mar 24, 2009 | X2Gen MG19MY 19" LCD Monitor
X2GEN MW19U MONITOR (THE SAME PROBLEM -SCREEN BLANK & CLICKING)
BEING A COMPUTER EXPERT (IT TOOK ME 6 MONTHS) TO REALIZE "DEFAULT" MEANT GOOD NOT LIKE BACK IN THE DAY!
STARTING FROM THERE, I NEVER EVEN THOUGHT OF WHAT MADE A MONITOR LET ME GAMES ON POGO & CHECK THE GIRLS OUT. I LOOKED UP "X2GEN" AND HAD NO PROBLEM FINDING OUT THEY DON'T LIVE THERE ANYMORE.
THEN I LUCKED ON YOUR SITE AND THOUGHT MAYBE (THE FUSE) SO MY LITTLE SCREW DRIVER REMOVED SCREWS AND LIKE MAGIC, X2GEN WAS UNPLUGGED AND THE COMPONENTS WERE SEPARATED FROM EACH OTHER.
NOT REALLY HARD TO BELIEVE I STILL HAVE NO IDEA IF THERE IS A FUSE IN THE THING..
BACK TO YOU GUYS AND FINISHED READING YOUR THOUGHTFUL SOLUTIONS.
I DO KNOW WHAT THE POWER SUPPLY IS ---"back to known stuff" --AND THOUGHT WHY SEARCH FOR A NEW ONE FROM THE POOR FOLKS THAT WENT BELLY UP MAKING THEM IN THE FIRST PLACE??? "NOW THAT'S DEFAULT"
THERE IS A FISH TANK POWER UNIT THAT HAS THE SAME NUMBERS - IF THAT DON'T WORK--DUMPSTER & WILL GET A MONITOR FROM SOMEONE THAT STILL HAS A JOB--GOT TO KEEP'EM WORKING.
I WAS VERY HAPPY TO FIND YOUR SITE AND ALL THE FOLKS THAT TOOK THE TIME TO WRITE HELP--THANK-YOU FOR REAL rg
Jan 27, 2009 | X2Gen MG19MY 19" LCD Monitor
X2GEN MONITOR LIGHT ON AND CLICKING
Hi...there,
Well, it is seems your monitor backlight inverter got burnt... need to replaced a new one or repaired it.
Dec 01, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen mw19u 19'' widescreen monitor going black
Try your monitor cable connections on both your pc and into your monitor.
Make sure they are TIGHT and level.
Also, it could be your video display card is faulty or your video display drivers are corrupt.
Try setting your desktop to a lower resolution, like 800x600 and see it that helps.
Nov 19, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
X2gen MG19E monitor
The only way to adjust the tilt on these monitors is to loosen the screws that attach the stand to the monitor. We had to completely remove the stand from the monitor to get to these stand screws.
Feb 12, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
264 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
