Recently purchased 1tb freecom 3.5" external drive 2.0 usb. I am using Vista, I have partitioned drive(not FAT).No icon showing on computer, cannot obtain any response. I am new to Computer technology so require plain language in helping me to fix this problem. I purchased this drive from I haven't informed them of my problem in using this drive. Thank you for your help. The literature provided by Freecom is not in 'simple' language for a learner
  • 1 more comment
  • derrick222 Oct 07, 2008
    The computer does not recognise the program - no icon is displayed
  • pop camplin
    pop camplin May 11, 2010
    hi there
    if you partitioned the external hard drive, the p.c. must have seen it at some time in order to do it.
    how did you partition it and with what programme, and what format if not fat ? i.e. n.t.f.s.
  • Donald Burt May 11, 2010
    does the computer recognize it
  • 102 Answers
SOURCE: Freecom Password Delete
Everything is possible. Few points. Is this external hd? Did you used the software and the drivers given by the manufacturer? Which OS are you using?
Yes it is possible to erase everything on any type of the drive and start from scratch. You can do this by formatting the drive make sure you do NTFS format.
Let me know please!
Posted on Dec 16, 2007
  • 1019 Answers
SOURCE: Freecom 250 Gb Hard Drive
Hi des,
you need to install windows XP, on a different hard-drive.
even if it,s only 10 gig plus.
You can then access the drive.
Your problem is here, is that you,ve upgraded from XP to Vista, theres a possibility, that you may have lost or even formatted your freecom hard-drive.
No-Support-Device detected, is saying that your USB devices are not functioning correctly.
Check in the bios that the USB devices are enabled, to operate your hard-drive. ( this is assuming it,s a USB drive )
Hope this helps you out.
Mike @ compurepair.
Posted on Mar 11, 2008
  • 75 Answers
SOURCE: Freecom 400 GB external hard
hi there,
sounds like you have a hardware should look into trying this drive on another system to see if the same thing is happening without the drive software ...and if it works try to recover all your data from this drive as soon as possible...hardware problems are most time intermittent ... so they work now then say after a while they stop...
Posted on Apr 13, 2008
  • 103 Answers
SOURCE: My computer USB drive is
Try this Link out to solve your problem...You need to install its driver and restart your window...
Good Luck
Genius Guy
Posted on Oct 16, 2008
  • 10 Answers
SOURCE: freecom
I'll assume your using Windows.
I'll assume it's a USB drive.
I'll assume it is an external drive.
And I'll assume it's formatted as NTFS.
Try using the USB (or FireWire) port for anouther drive to see if that is the problem, if it is then reinstall the driver for the port, through the Computer Managment Concole (assuming yur using windows).
If you formatted the drive as FAT, re-format it as NTFS.
Posted on Jan 02, 2009
Are they any way to restore a 1tb back to 1tb
Fat 32 is the Format style used for several Solid State drives. This is NOT relative to Space on the drive. Space is Related to what we call a Partition. If the entire drive is partitioned to the max., you will not get a total of 100% (1000G) but somewhat less. Insert the USB drive and when you find it in the File Explorer, find the Drive and Rt.Click. Select Format from the listing. Use the Option "Restore Device Defaults".
Dec 29, 2013 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Used drive once, now computer doesn't see it
try restarting computer with drive plugged into usb but no power on drive
once computer is all on, then power on the hard drive
May 24, 2012 | Freecom Xs External Usb Hard Drive 1tb
Cant remember password to wd external hard drive Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
May 25, 2011 | Western Digital My Book Essential 1TB...
OK so this is a replacement 1tb hard drive which i have only been using for about a month. Basically the lights are on, and the drive still makes sounds. When i unplug/plug it into usb port it makes the...
Feb 26, 2011 | Western Digital My Book Essential 1TB...
New 1TB My Book Essentials ext drive not recognized by laptop
There are times when external drives need to be inialized and formatted before they can be recognized by a computer. There are other times when the drive letter that the external is looking for is already being used and it does not show up.
You can use the disk management utility to initialize, format or change drive letters around. You do not want to change your C drive, also usually called drive 0. Below are directions for accessing and utilizing this tool:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
This should get you to see your external. If you don
Jan 16, 2011 | Western Digital My Book Essential 1TB...
I want to format my 2 T hard drive from NTSF to fat 32 , how to do please help
Ok this fix will erase all Partitions on the drive, Make sure you have all data back'd up.
Open Command:
Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator. Or Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
You should have a black MS-DOS prompt on your screen. Type DISKPART in and press enter. Another window will open
Type: list disk It will the display list of devices with memory storage. Find your disk, It should be in a Table(kinda). You have to locate it by its size. so look for 1TB(1000GB) In this Example its Disk 2, yours may differ.
type in: Select disk 2
Wait for one command to complete before running another
You should be left with a working FAT32 Device :P
Regardz Sinn3D
Oct 27, 2010 | Western Digital My Book Essential 1TB...
I have a 100g usb hard drive that i have my music on.. i was wondering how to connect it to my ps3 like a flash drive does?
here you go
Connect the hard drive to your computer using a USB cord.
Check what the "File System" type is by going to Start, Control Panel, Administrative Tools, Computer Management, Disk Manager. Select the external drive and read the "File System" type. The file system type must be "FAT32" in order for the Playstation to recognize it.
If the file system type is "NTFS", right click and select "Delete Partition" or "Delete Volume" for Vista.
then recreate the partition but do NOT format it. Make sure you assign a drive letter (for this Tutorial, we'll use h:)
If you are running Windows, format the drive by going to the command prompt (Vista, right click on command prompt in start menu and click "run as administrator")and type in "format h: /FS:FAT32" (without the quotes). You may need to substitute your drive letter. (note this might not work on XP for a large hard drive - you may have to use a third-party formatting utility like SwissKnife; however, it does work under Vista - just be sure to use the format command from the DOS prompt, not from Windows Explorer)
If you are using Mac OS X, open /Applications/Utilities/Disk, pick the drive, and click on the 'Erase' tab. Pick 'MS-DOS (FAT)' for the file system type, and click on the 'Erase' button. This will reformat the drive in FAT-32.
Open "My Computer" and double-click on your empty external hard drive.
Create a folder system identical to that on the Playstation 3 by creating folders labelled "Picture" (not Photo), "Music", "Video" and "Game".
Load all the music you want into your music folder, all the video you want into your video folder, and all the photos you want into your picture folder. Your game folder should still be empty.
Disconnect the hard drive by clicking the green arrow in the icon list and the bottom right hand corner of the screen and select "Safely remove..."
Once your computer tells you "XXX drive can now be safely removed", unplug the hard drive from your computer.
Connect the hard drive to your Playstation 3 and use the extra space to save information and access all your extra content saved on your external hard drive
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
WD Elements 1TB stopped
I would remove the data with another computer using a usb adapter and then re format the drive but check your motherboard will support more than 528Gb chunks. If it won't, partition the drive accordingly.
Jun 11, 2017 | Computers & Internet
Freecom 400GB Hard drive not recognized.its a Freecom mobile drive xxs 400gb , my pc just cant recgnize the hard drive
Jan 02, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
