Question about Saeco Royal Professional Espresso Machine
After descaling the Saeco Royal Professional, all features remain functional except for the coffee dispensing. It will grind and the brew unit will go through its usual cycle, but no coffee will get dispensed. It sounds like there is simply a bunch of steam being created inside of the machine.
  • Anonymous Oct 19, 2008
    Hi, I've exactly the same phenomenom, will now try and 2nd descaling and keep ya posted :o)
The first descaling cycle likey dislodged some calcium which then found its way into a valve or water line. A second descaling cycle resolved the problem.
Posted on Oct 07, 2008
I am getting no coffee to dispense out of the coffee output. It gives me no error message. It grinds the coffee and acts like it is dispensing the coffee. But nothing comes out. My coffee grounds...
firs of all try to make preground coffee ,but without coffee powder if the water come out then you have to change the pump. If no water come out -your machine needs to be descaling
Oct 18, 2013 | Saeco Royal Professional Espresso Machine
I have a Saeco Royal Coffee Bar that will intermittently fail to dispense espresso. It will grind the coffee but instead of dispensing the coffee, it dumps the (dry) coffee into the dreg drawer and resets...
Hi
Its not the water. More than likley its the lever on the right side of the machine at the top middle of the door. Its pushed all the way to the back or positive. Move it 1 mark towards the front of the machine and try again. If you put too much coffee in the brew unit, it can't compress it and kicks it out. It could also be your grind is too coarse. It should look like auto drip coffee.
Apr 02, 2011 | Saeco Royal Cappuccino Espresso Machine
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
HI
There is a lever on the top of the door that has a + to the back and a - to the front. Pull the lever back 1 click to the front or - side. Your putting too much coffee in the brew unit and could break the brew drive.
Nov 30, 2009 | Saeco Royal Professional Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Machine grinds but doesn't brew
Hi Donna,
Try to factory reset the machine in the meny.
Apr 13, 2008 | Saeco Royal Exclusive 30153 Espresso...
Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Jan 11, 2008 | Saeco Royal Professional Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
219 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
