Question about Refrigerators
Zanussi intelli. set fridge/freezer constant bleeping, no flashing lights and temp seems ok. Please help
  • melguing Mar 05, 2009
    zanussi intelli set fridge freezer constant beeping, lights flashing. turned it off, reset the flashing buttons beeping just starts again. fridge and freezer is still working fine but noise is doing my head in.
  • Anonymous Apr 17, 2009
    sometimes my zanussi fidge freezer makes sounds when all three buttons are lighting
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
MATRIX_MMX
  • 209 Answers
SOURCE: zanussi fridge freezer
dear plapy
This to me sounds as if either your gas is not circulating through the refrigeration system, or you have a problem with thermostat. If you have recently physically moved the fridge and then powered the appliance up on the mains without letting the gas settle, then you could have damaged the fridge. And there is not really a lot you can do about this, unless you want to call out a refrigeration engineer to re-gas your fridge and assess the circulation of the pumped cold air flow.
Other problems aside of gas and thermostat could be associated with the pump (if your model has one fitted), and with this in mind, i have a good mind to have a look at the SIOS (spares, Information, Ordering, System) disc for zanussi vendored models and then get back to you once i have a further solution for you. However, I will need your make and model of zanussi fridge, so if you have this to hand it will be most appreciated. In the sad event that you dont have the paperwork/ manual for the fridge, then you can find the manufacturers model details on the rear of the fridge. however, when you move the fridge, you will need to let it stand again before powering up the unit after repair, and this should be done for a period of no less than 24 hrs, and no less than 28hrs if your appliance is a fridge freezer combi.
So once again, when i recieve further information regarding your make and model of refrigerator, then i will be able to fully investigate this matter for you, and try to come up with your most appropriate solution..
In the mean time, i bid you take care, and hope to hear from you soon
Yours sincerely
oz
Posted on Apr 11, 2008
SOURCE: whirlpool s20b fridge/freezer
858615215011 temp. indicators and night light flash continuously.
Posted on Apr 12, 2008
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
SOURCE: Samsung cool n cool fridge
fridge is not getting cold freezer is ok
Posted on Jan 26, 2010
Why is my upright fridge freezer bleeping constantly, both fridge and freezer cooling ok
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
Zanussi Intelligent Intelli-set Fridge Freezer
bonjour je souhaiterais avoir le sch
Sep 14, 2010 | Refrigerators
Zanussi ZX97 temp light bleeping freezer has defrosted
It may be low on gas.There is a p.c.b. control on the top panel which has a cable going to 2 sensors to control the unit temp.If they are faulty here are the Electrolux part nos.
P.C.B. 2147187088 $93.
Sensors. $37.
Hope this helped.
May 17, 2010 | Zanussi ZX97 / 5 Bottom Freezer...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool s20b fridge/freezer
Mar 27, 2008 | Refrigerators
Power light flashing on & off
Try to unplug and plug the power cord this may help, flashes is an error code. Try also the defrosting, error codes alarm the owner if there are some abnormal operation int the unit.
Jan 08, 2008 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
966 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
