Monitor heater I keep getting an error 13 message
  • 4 more comments
  • nikiki815 Oct 08, 2008
    Same message, seems like its gonna go on for about 5 minutes and then beeps "E 13" on the screen. Manual only discusses E14 as being out of fuel...what the hell.
  • walkeraqha Nov 11, 2008
    hey we are having the same problem runs a couple of minutes then beeps E13 and are fuel tank is over 1/2 full walkeraqhaAaol.com
  • Anonymous Nov 18, 2008
    my heater thumps when in burn mode then shuts down shortly after and e 13 is shown???
  • japettler Nov 20, 2008
    I'm having the same problem.
  • pward757 Nov 23, 2008
    What does e13 mean I have the same problem
  • ATMHicks Jan 11, 2009
    Having the same E13 problem. Tank is 3/4 full. Manual speaks of E14 but not E13!!! Please help!
He's probably right, my problem wound up being that someone sabotaged my landlord's tank and filled it with water. Water is more dense then Kerosene, so it sunk to the bottom, got into the heater and ruined it so that it stopped working every time it got cold outside. They had to replace everything...hope it's just the water in the filter for you guys and not what happened to me!
Posted on Jan 18, 2009
If it is cold outside, below freezing the filter may have some water trapped in it, clean the filter and replace element in it and retry
2 Suggested Answers
  • 126 Answers
SOURCE: we have a monitor 2400
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Posted on Jan 19, 2009
Error 13 monitor 2200
Check the pump pressure & purge the pump
Dec 17, 2013 | Heating & Cooling
I am getting a 13 error code . jim B.
Before calling service technician, open following links for troubleshooting resources including Rheem chat and typical manuals:
http://waterheatertimer.org/pdf/Error-code-13.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
All gas water heaters require periodic maintenance.
Tankless recommend yearly maintenance.
Typical maintenance would cover most the causes for error 13, plus causes for most other common error codes.
Jul 19, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
Screen Resolution Error Message
go to control panel look up display adjust it ok;
Apr 30, 2010 | Envision 19" Widescreen Flat Panel LCD...
I'm getting an "E 13" code on my Monitor 2400; what does that mean? I don't have a manual to tell me.
E 13 means ignition failure. You can see a list of error codes at www.monitorproducts.com. What happens when you try to light the heater? You can contact me at nitensheaterservice@embarqmail.com.
Jan 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Paloma tankless ptg42 water heater error code c4/13
4 error message, the 4th (last) error code is #13, not enough oxygen.
Check the location of the heater, if it is fine the ODS sensor (actually is a thermal couple) is bad.
Dec 25, 2009 | Rheem Paloma Tankless Water Heaters...
Display error
The blood pressure monitor will display an "err" error message for many reasons. It could be the cuff is too small for the arm or wrist. Most wrist monitors measure up to 8.5 inches & arm monitors measure up to 13 inches. If a larger size is needed, then check with a pharmacy for larger sizes. Sometimes placement of the arm is wrong or the tube is not lined up correctly on the arm or the tube is not sealed tightly into the monitor. Sometimes body movement during a reading can cause an error. It is best to check if any of these occurrences happened before the error message occurred.
Sep 06, 2009 | Health & Beauty
We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
Tom Hawkins
hawkins111@gci.net
Jan 19, 2009 | Heating & Cooling
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Error message
9,037.45 Yellow Ink Stick Count Fault
your 04,021.42 here are the possibilities.
arrwup.gifPrimary Causes The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure.
Table 1. 4,0xx.4x Troubleshooting Reference Table Applicable Parts
Wiring and Plug/Jack References
Electronics Module, PL 5.0
Right Side Wire Routing (2/2), Figure 3
Printhead, PL 2.0
Electronics Module, Figure 6
Drum Assembly, PL 2.0
Electronics Module Power, Figure 7
Drum Heater Relay Board, PL 5.0
Right Side Wire Routing (1/2), Figure 2
Drum Temperature Sensor, PL 6.0
I/O Board (2/2), Figure 10
arrwup.gif Troubleshooting Procedure Table 2. Process Control Error Troubleshooting Procedure Step
Questions or Actions
Yes
No
Test the heaters.
Run the Service Diagnostics Monitor Heaters tests with all heaters On.
Do the heaters function properly?
Replace the Electronics Module ( REP 5.0.5).
Go to Step 3.
Check the harness to the failed heater.
Is the harness damaged?
Replace the harness.
Replace the failed component.
Jan 06, 2008 | Xerox Phaser 8500N Printer
Heating & Cooling Logo
523 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
