CANON i70 ERROR MESSAGE 5100 PRINTER BLINKS (RESUME YELLOW BUTTON) 8 TIMES. WILL NOT PRINT ANYTHING ALL THE WAY THROUGH.
5 Suggested Answers
SOURCE: Canon i70 Printer failure - constant flashing orange/green
jepp
Posted on Mar 23, 2008
IrishDruid
  • 2712 Answers
SOURCE: Canon i860 - Service Error
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME (while still holding down the POWER)
3. press RESUME twice, then release POWER
4. The green light will blink and the printer will make some noise. Wait until this is finished, you are now in the printer's diagnostic mode.
To select one of the functions below, use the RESUME button and then press POWER to execute:
# of RESUME Presses - Light Color - Function
0 - green - Power Off
1 - orange - Service Test Print: Extended nozzle check pattern
2 - green - EEPROM information print
3 - orange - EEPROM initialize
4 - green - reset waste ink counter (For the Canon waste tank full error)
Remember... ATTEMPT THIS AT YOUR OWN RISK!!!
Posted on May 03, 2008
  • 49 Answers
SOURCE: Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Posted on Jul 06, 2008
SOURCE: 4 flashing yellow lights on
I caved in and payed the Canon technician $10 for troubleshooting to find out that this code means there is a hardware failure if you are still getting the four flashing amber/orange lights on startup.
After visiting cartridge world I was informed that they have seen this numerous times before and are convinced the printers are rigged to fail. Essentially they told me that Canon created printers to die after a certain amount of use, which only makes sense considering my printer sat in the same spot for 5 years. How could have it suffered a hardware failure if it was never dropped, let alone moved.!?!?!
Their manufacturers manual says to replace your printer if you have this issue. Old printers, I was told, did not have motherboards, and since their invention it's become apparent that these companies have their hardware wired to fail after a certain time/amount of use. Typically people start to see the ink tank error, the printer head error/failure, and then the hard drive error/failure, which is EXACTLY what happened to me. All they want is for you to purchase new parts, pay for technical support, and pay ridiculous amounts to have parts replaced. It's that or get a 15% discount on a new model that probably costs upwards of $200.
Shame on Canon. I will never buy their products again. Save your money and get a laser printer where you can replace the hard drive in the printer if it "expires".
Posted on Nov 03, 2009
pineworks
  • 4041 Answers
SOURCE: Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
I am getting error message 5100....can't locate the manual...Any ideas? Thanks!
Error 5100 indicates "carriage jam". The carriage is the assembly that contains the print-head and ink cartridges. This error can be difficult to solve because various things can cause it.
Make sure the ink cartridges and print-head are installed properly. Remove them and re-seat them.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've never done it before. If this does not work, unplug, wait 3-4 minutes, then re-plug in.
Jan 15, 2011 | Canon PIXMA iP1600 Printer
PIXMA MP 450
try these steps ...
1. Turn off printer
8. Your printer should respond as normal..
Aug 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Error 5100 when I try to print anything . bought it few hours ago can any body help?
hi try this 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
Jun 09, 2009 | Canon PIXMA iP1300 Printer
Print Sometimes, and Sometimes Error 5100
1. Turn off printer
here is the link for other printers: http://www.cyber-ink.com/member-canon.html
Jan 08, 2009 | Canon PIXMA MP470 All-in-One Printer
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Printer will not print
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions
If its still persist follow these steps to reset the printer and it work i hope it will help you in yours.
Reset ip2000 / 3000
1. Turn off printer
Nov 15, 2008 | Canon PIXMA iP1600 Printer
Jul 05, 2008 | Canon BubbleJet i70 InkJet Photo Printer
SERVICE ERROR 6000
Use this:
1. Turn off printer
5. Green lights will flash and stop blinking.
May 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
green.
Dec 18, 2007 | Canon BubbleJet i70 InkJet Photo Printer
165 people viewed this question
k24674
