Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Wire connecting I have 10/3 power coming to unit. I have nowhere to hook my white return line. What do I do?
    Scholar:
  • 147 Answers
You dont need the white wire. you only needed 10/2
Posted on Nov 06, 2008
I need to install a White Rodgers transformer thermal control relay combination on my gas furnace but I am not sure of the wiring connections.
This is going to be a tough one to explain, but from the schematic I found, this is a transformer/controller all in 1. So we are using this 1 module for 2 purposes. The R terminal should connect to the wire that's connected to R at the thermostat. And the C terminal should connect to the C wire coming from the C terminal at your t-stat(if used), as well as your common that returns power from your contactor at the o.d. unit. You'll have 2 wires going to the o.d. unit, 1 connects to Y and 1 connects to C to the 8a501 box. The G and W should also be connected to the wires that connect to G and W at the t-stat. That is your low voltage side. Now, this line voltage side is more difficult. You'll need to know what wires are your fan speed taps on your blower motor. And also, does your unit close the N/O(normally open) contacts for heat or cool? Normally it closes for cooling, so your high speed wire would connect to the n/o wire, and your line voltage supply would connect to the bulk/yellow. And then your medium or low wire from your blower would connect to the N/C wire. The schematic is there on the side of the module. This may be beyond your experience and may cause motor winding failure with in seconds of operation. Also, ensure with a volt meter that all power is disconnected! And all run capacitors are discharged! I've not wired 1 of these modules but from the schematic, seems simple, AS LONG AS YOU KNOW WHAT THE MOTOR SPEED TAPS ARE. Hope this helps, and if you're unsure, call a professional. The labor should be less than the cost of a damaged motor.
Aug 20, 2017 | Heating & Cooling
Cd changer connections
Hi, On your Audiovox ACC56 10-Disc CD Changer with a Prestige P-165/P-185 FM Modulator, the wires: black - goes to the body (-) ground (as you correctly posted); Green/white - (with a small filter box) goes to the constant/always on 12V supply such as the + terminal of your battery Orange/White - should be connected to a switched power source such as the accessory terminal of your ignition switch or to the blue or yellow wire of your head unit or car stereo or whatever wire that will have 12V+ only when the head unit or car stereo is switched on. Hope this be of some help to you. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | Audiovox ACC56 10-Disc CD Changer
PowerStar AE9.5 isn't working. Bought new. Water lines are hooked up to the correct water lines. The 240V wire coming from the breaker is hooked up as follows: Uncovered copper wire connected to ground,...
The unit will not owrk unless you have 240V ACROSS the black and white wires...if you do not have that coming to the unit then you have a bad breaker...
heatman101
Feb 19, 2011 | Bosch PowerStar AE9.5 AE9.5 Point-of-Use...
There are three black wires coming out of thefuel pump and sending unit 2 with white lines on a 2000 chevy blazer are they all ground wires
I don't know what you mean because the pump black power and white ground would be much thicker then the fuel gauge sending unit black power and white return. The fact there may be an addtional chassis ground should not be confusing. All you have to do is connect one wire at a time, just as they are now. I don't see how you could get them mixed up? Don't they go to a keyed plug?
May 28, 2010 | 2000 Chevrolet Blazer
My house wires from the electic stove top has 3 wires and my new bosch electric top has 4 on red, white, green, yellow?
hook the red and yellow off the new stove to the two hot phases-then connect the white on the new unit to the neutral power connection and finally the green wire can hook to the same neutral wire also as long as the power comes directly from the main electrical panel in the home, but not a sub-panel
Nov 15, 2009 | Bosch 30 in. NET7452UC Electric Cooktop
T101 R Clock will not turn
The "Line" is the power source. The "load" is the device that is being powered.
typically the green wire is the ground wire. I strongly urge you to verify your assumption that is is the common wire. If the green is indeed the ground, and it gets hooked up to common, you will be energizing the cabinet of the unit and posing a serious shock hazzard.
Your curcuit will be as follows.
The power source "Line" will have wires going to the timer. (hooked to the "line" terminals on the timer.)the timer then is supplying the power to the pool pump, and we will reffer to it as the "line".
The two black wires from the pump would be hooked up to the "load" side of the timer.
Typically they would be labled line 1 and line 2 or "L1" and "L2"
If yours are not labled so, describe exactly what terminals you have in detail in both the pump and the timer.
Oct 03, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Need to connect 3 wires from pole to 2 wires in unit
It sounds like a 120 volt line coming in from the pole. Red is the hot wire, white the common or neutral wire, and the green ground. Hook the red and white to the two main wire lugs in the unit and the green goes to the frame or ground lug that will tie to the frame.
Jul 12, 2009 | Heating & Cooling
How do I connect a line output converter to my factory head unit
depending on the type of line out converter that you have you simply just take the speaker wires coming from the head unit (you must know the color codes for the wires or you can do the process of elimination by pulling off the door panels and and viewing the colors and matching them at the wire harness behind the head unit). Pull out electric fuse for radio so you dont blow it while hooking up the wires. After you have done that just connect the speaker wires coming out of the head unit to the line out converter this will pre-amp your signal. After you have done that step on the other side of the loc you will have to connect and run rca audio cables to the back of your car to hook into your amplifier. The last step is to splice the power and ground wire coming from the wire harness and connect the radio power wire and loc power wire to the main power wire and then connect the radio ground wire and the loc ground wire to the main ground wire. Test and your done with the loc.
Aug 12, 2008 | 2008 Chevrolet Impala
Unit trips circuit breaker when plugged in
On AC current it really makes no difference to the operation of the unit which terminal the wires are connected to as long as the circuit is completed. A reason for the inverted wiring is that there will be a resistance between the hot wire and the control circuit. It makes for a reduced load on the contacts and switches minimizing arching.
Jun 08, 2008 | Maytag Portable Air Conditioner M6P09S2A
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
47 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
