Question about KitchenAid Dishwashers
Water into dishwasher tub wont shut off resulting in overflows
I have a ten yr. old kitchenaid superba dishwasher.  I've looked everyone for serial number, etc. but dont see it.  Tell me where to look further and I'll get you a serial number.
Can you guess at why the water wont shut off going into the tub.  If I don't turn supply line off my kitchen floor is flooded.
Many thanks, Susan
  • ffarrell Feb 10, 2009
    kuds24se water will not shut off resulting in flooding. Water continues to fill even during the Cancel cycle.
  • 943 Answers
Hi susan. the problem is with the water valve, which is located behind the bottom plate, of the dishwasher. remove . water valve, is on the left. thanks the appliance doc
Posted on Oct 06, 2008
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
HI, I have a KSRL25FRSS00 side by side. The icemaker fills with water and freezes, but doesn't dump the ice cubes. I've used a hair dryer on it to melt the ice a little and have got it to dump the...
There is a heater in the ice tray that is supposed to thaw the cubes a little bit so they don't stick to the edge of the tray. When the heater does not work the ice sticks and the motor wont dump them out. You can see more info and comments and how to here: http://www.appliancepartspros.com/repair-help/kitchenaid-refrigerator-ksrl25frss00-repair/ksrl25frss00-ice-maker-wont-dispense-ice.html
Jul 28, 2017 | KitchenAid Superba KSRG25FK Side by Side...
1 yr old kitchenaid KUDE70FVSS2 dishwasher just started making grinding noises when the pump runs during the draining cycle and some water remains in the tub now. no issues with operation until now. i...
your better off just replacing the pump. you probably have broken glass or something else stuck inside the pump. to get to it you're going to have to remove the kick panel from the bottom of the machine. just follow the drain hose and you will see the pump.
Jul 16, 2011 | KitchenAid KUDE70FVSS Builtin Dishwasher
I have a 25 ft Kitchenaid Superba, probably 5 years old or so. It just started to get a large buildup of frost/ice on the surfaces where the ice maker tub joins the ice chute in the door. I have taken the...
There may be a small leak in the pipe at the place of joint which lets small amount of water out and it may be this water that freezes. Have a check of that tube and if necessary get it replaced.
Apr 20, 2010 | KitchenAid Superba KSRG25FK Side by Side...
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
Water overflowing in ice maker.
I just replace my kitchenaid icemaker. My model is 4317943. And it comes with a sheet of menu. I scan a portion and hope it will help.
Apr 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwashers Logo
226 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
