How to change screen from wide to standard on asus w3h00v?
From time to time for work, I would like to change backwards and forwards screen (settings) on my laptop asus w3hov from widescreen to standard screen. Using Windows XP professional ver 5.1 service pack 3. Have tried to change in Display Properties/Settings but no luck Can change resolution but this is not what I want, this does not change screen from wide to standard. Could you please get back asap. Thanks, Paula
Bulova wall dual chime clock stopped yet pendulum works.Hands are free. Chimes will work. Battery still too low?
I am not familiar with this clock but ask did you just turn it backwards one hour, if so then I have found some do not like this while others are not so fussed.
I think maybe its mechanics have jammed a bit, I would try to move it forwards an hour or two and see if it restarts, once it starts to work gently move it forward a bit at a time.
Figure you have tried a new battery, sorry best I can think of.......
Nov 06, 2016 | Televison & Video
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Change screen from wide to regular our cable guy put it on wide my control will no longer change it
Vizio has a set of buttons on the left side where you can access your settings and change the aspect ratio of your TV. Though why you want it changed is beyond me. Wide screen is for 16:9 aspect ratios. At 4:3 (Standard) you won't be using your full TV picture.
May 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
Screen set up will not change
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
raterakash12
Jan 07, 2010 | Nintendo Wii Console
Keyboard errors on Asus Eee pc 1000HD
sounds strange but ...
1 - check the mouse settings
2 - or ... turn-off the touchpad (under "touchpad settings")
3 - check/reset "keyboard settings"
see if you can narrow this down, with some detective work.
Apr 07, 2009 | ASUS Eee PC 701 Notebook
Wide screen problem
Try adjusting the setting of the video card instead. right click on the desktop and select properties and setting. select the screen resulution that fits your monitor.
Most monitors are plug and play and does not need a driver.
Mar 29, 2009 | ASUS VW192S Monitor
Player won't play certain dvd's
the password is the arrows you have to do forwrd,backward,forward,backward but use the doubke arrow keys. this should work i found the soloution the manual
Mar 12, 2009 | Disney Hannah Montana DVD Player
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
