Question about Sony MDS-JE480 Mini Disc Player
Mini Disc Not Working
Hi,, machine on standy have put a disc in ,red light shows MDLP display, nothing responding,am pressing various buttons on the machine and on the remote nothing is happening but am able to eject the disc.
Pleeeese Help as i need this for my roadshow as DJ.
  • Anonymous Jan 17, 2009
    I have a similar problem. I have a MDS-JE510 and when power button is pressed it goes from RED to Green then back to RED. Display then shows STANDBY. When I insert a disc the power botton goes from RED to GREEN but disc will not insert then power button then goes back to RED and display shows STANDBY again. Not sure if there is a FIX for this.
  • Sony Expert
  • 509 Answers
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
Posted on Sep 01, 2009
SOURCE:
How do we get the machine to start?
Hi,I dont know if this is eney help but I just bought a tassimo - coffee machine and it sounded just like you described yours,
I pluged it in,then I took the water container of the back where I found a yellow disc,(do not remove the bar code from the yellow disc other wise the machine wont work) I inserted the yellow disc where you put the t-pods,then fill water - container and put it back in place,then I switched the on switch on,it should show a yellowy orange light nexst to the silver button,then press and hold the button for 5 seconds and let go,the light will flash and turn green,then give it another 5 seconds then hold the silver button in again it should now despence hot water ,when water stops press the silver button again do this about 4 times,now your machine is ready to use,take the yellow disc out and put it back in the place you got it from,
now just put the t-disc you want to drink and have a rest.
I hope this was some help.
Feb 11, 2015 | Krups Coffee Makers & Espresso Machines
Hi, I have a Sharp DV-RW360H which has been working fine. I have dubbed various VHS tapes to DVD and now need to finally the discs so they can play in other machines. However when I press the setup button...
Try one of the discs in another machine. You only need to finalise them if you want to ensure no more is put on them. To finalise a disc you need to use the write or burn functions, not the setup menu. Get the manual for this from the sharp website and read it.
Dec 15, 2013 | GoVideo DV2130 DVD Player/VCR
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Hi,I have just bought a Denon dn m991r second hand and I am having problems recording on analog.I press record and DIGITAL IN starts flashing on display,I press play/pause button but nothing happens no...
Go here - http://www.minidisc.org/part_Denon_DN-M991R.html . Get the owner's manual. Read it.
The preset mode changes whether you record analog or digital.
Assuming nothing is jamming or is bent, the weak eject is probably why the guy sold it to you. It can't hurt to take the cover off and watch what happens.
Aug 05, 2012 | Denon DN-M991R Mini Disc Player
I have just put a blank disc into my sony mds s40 to record but now nothing works on the player....i just keep getting a small red flashing toc, i've tried unplugging from mains then re connecting but...
You may have the disc shutter closed preventing recording. You should never interrupt the recorder when it is trying to write to disc, you probably corrupted the table of contents (TOC) on the disc and need to reformat it to use it again.
If your deck is older you may have worn out the recording heads preventing it from writing to the disc in the worst case.
May 07, 2011 | Sony MDS-S40 Mini Disc Player
MDS 503 STUCK IN STANDY MODE?
Is it an MDS-JE530? Do you have a minidisc in it? If yes, then unplug the unit. Slide the little switch from TIMER "OFF" to "PLAY", then plug the unit back in. After 10 seconds, it should turn on and start playing the minidisc. Let me know if that works or if we need to try something else, okay?
Dec 30, 2009 | Sony MDS-JE520 Mini Disc Player
'disc mode'displayed in window, large tick and o.k to disconnect. machine will not respond.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If for any reason this does not resolve your disc mode/frozen iPod issue please do let me know and remember to rate :)
Mel
May 20, 2009 | Apple iPod nano
Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Sony MDS-JE480 Mini Disc Player Logo
264 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
