Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi WS-55513 blinking light
I have a Mitsubishi WS-55513 tv and after a power outage it will not turn on and the green light by the power button is blinking.I've tried the reset button and unplugging the power to no avail.This tv from brand new has had a history of shutting down on ocasion but would always start back up untill now.
  • 1 more comment
  • Terry Palmer Oct 07, 2008
    Tried unplugging the tv for an extended period and did not get any results
    The link that I got for the service manual did not have a ws-55513 listed.Does that make any difference?What procedures do I have to go through to check the power supply{fuses?)?
  • Terry Palmer Oct 10, 2008
    took the advice of terryfic and replaced the 4 capacitors solving the problem
    Genius:
  • 1,011 Answers
Dear,
did u tried by replacing cap. if not then check it plz
regards,
dont rate it untill it helps or solves
Posted on Oct 07, 2008
    Genius:
  • 1,239 Answers
HI you have a power supply problem you need to have a tech fix it the power supply is bad
  • ABHISHEK.C
    ABHISHEK.C Oct 07, 2008
    That is a convergence problem, to fix it it is necessary checking the soldering at the yokes, test horizontal convergence IC, test a couple of capacitors and resistors on convergence circuit, and sometimes the technician may have to replace the whole convergence pcb inside.
  • 171 Answers
Click on the link below. It is the service manual, for technicians (very rare) and you shall have all of the information you need to work on this unit forever, Let me know if you need additional assistance as I am prolific in this field.
http://www.techlore.com/downloads/file/7714/VS-50111,_60111,_WS-48311,_55311,_65311,_WS-55411,65411,_73411-2.pdf
  • Mitsubishi Master
  • 19,396 Answers
Try first unplugging power cord for one hour.
Posted on Oct 06, 2008
  • Ginko
    Ginko Oct 06, 2008
    If the TV does not turn on, it can have an internal fault.
    When the
    TV main chip detects a problem, like a faulty component on tv board, it
    will prevent TV from switching on, and the unit will stay in standby
    mode. When this happen it is said that the tv is in protect mode.
    Often, after apower outage, the TV goes in protected mode, and you wake it up leaving it unplugged for a certain time, if one hour is not enough , try leaving cord unplugged overnight, also unplug all the other cables.
    If it does not depend on the remote, and the tv is in protect mode, try unplugging tv power cord for one hour or so.
    If this does not work it means the tv is faulty, call the number listed on the user manual to have it repaired.
  • Ginko
    Ginko Oct 07, 2008
    If unplugging the TV did not work, that means that the unit is defective.
    Common problems on TVs affect the power board and other internal parts, but guessing what the problem is , it is not of any use. The TV set must be tested personally by a repairman.
    Unless you have experience in fixing TVs you will need to call a technician on site.
    Servie calls start from $80
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
My tv green light comes on but then turns back off cant watch tv why is that
when you turn it on and then the green power light goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for at least 5 seconds and then release both.
The green power light should blink a error code at least 5 times: most common is 2 blinks, pause and 2 blinks----
Let me know what error code you find and I will tell you what it means--2,2 is the most easy to fix and common.
SD TECH
Aug 03, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
