Question about HP DeskJet 5550 InkJet Printer
Cartridges locked to the right and all lamps flashing
See subject
    Scholar:
  • 105 Answers
I think you have misplaced the cartridges, i.e. , you have placed them into wrong slots.
You may need to contact you local support to get the issue fixed.
good luck
Posted on Oct 17, 2008
When I press the shuuter button down my D80 flashes a bright light. I have tried switching the modelling flash function to off, however this has not solved the problem?
That's called an "autofocus assist lamp". When you prepare to take a picture in low light, the autofocus can struggle to lock on to your subject. The lamp you talk about, illuminates the subject for a moment, so that the autofocus can 'see' when correct focus has been achieved.
It is indeed annoying, but this is the price you pay for sharp photos (it's not possible to wait for the flash to go off, and focus in that moment). One 'solution' would be to turn the focus assist lamp off and live with the poor results. Another 'solution' would be to switch to manual focus. Or you could let the camera focus normally once, apologise to your subject, turn the focus to manual without changing it, and then taking more pictures without the annoyance (but you might have got a good picture the first time, anyway).
Jan 20, 2011 | Nikon D80 Digital Camera
I have a 2000 pontiac trans am. when i set my alarm my haedlight pop up. they never use to. replaced module,and headlight motors,still didn't fix it.
In your owners manual on pages 2-19 and 2-21 tells you how to change this.
Entering Programming Mode
1. Turn the ignition key to RUN, then to OFF. This will
disarm the content theft-deterrent/alarm system
(if equipped).
2. Remove the RADIO fuse. This fuse is located in the
main fuse block which is located on the left side of
your instrument panel. The radio fuse is on the lower
right-hand corner of your instrument panel. See
"Fuses and Circuit Breakers" in the Index.
3. Turn the ignition key from OFF to RUN three times
quickly (within five seconds). The vehicle will
respond by locking the doors, unlocking the driver's
door and releasing the hatch. Your transmitter is now
ready to match the vehicle. Leave the ignition
in RUN.
4. Press and hold the LOCK and UNLOCK buttons on
the first transmitter for 15 seconds. The vehicle will
respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your
transmitters, replace the RADIO fuse.
7. Check that all transmitters work by pressing
the buttons.
Programmable Modes
Your vehicle can be programmed to one of the
following modes:
Mode 1: All Off (The headlamps will not flash and the
horn will not sound to provide you feedback that a
lock/unlock command has been received by the remote
keyless entry transmitter.)
Mode 2: Horn and Lamps/Lamps (Your horn will sound
briefly and your parking lamps will flash when you
press LOCK on the remote keyless entry transmitter.
Only your parking lamps will flash when you press
UNLOCK.)
Mode 3: Horn and Lamps (Your horn will sound briefly
and your parking lamps will flash every time you push
LOCK or UNLOCK.)
Mode 4: Lamps (Your parking lamps will flash every
time you press LOCK or UNLOCK.)
Mode 5: Lamps/Horn and Lamps/Lamps (Your lamps
will flash upon the first press on LOCK, your lamps will
flash and your horn will sound upon the second press
on LOCK and your lamps will flash upon any press
on UNLOCK.)
Vehicles are delivered programmed in Mode 5.
To change the mode, do the following:
1. Press the UNLOCK button on the remote keyless
entry transmitter.
2. Count the number of chimes you hear. The number
of chimes tells you which mode your vehicle is
set for.
3. Press the UNLOCK button, again, on the remote
keyless entry transmitter until you hear the number
of chimes that correspond to the mode selection
you want.
The mode you selected is now set. You can either exit
the programming mode by following the instructions
later in this section or program the next feature available
on your vehicle.
When programming is complete, turn the ignition to
OFF and reinstall the RADIO fuse.
Sep 20, 2010 | 2000 Pontiac Firebird
The ink lamp flashes even though it is a new cartridge and is prining fine how can i stop it flashing
the ink lamp flashes even though it is a new cartridge and is prining fine how can i stop it flashing
Feb 27, 2010 | Canon FAX-JX200
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
The orange lamp always lights
depending on how many times the orange light flashes. if 4 flashes then the ink has run out. if 5 flashes then it can not recognise the ink cartridge, if 7 flashes then the ink is not installed properly.
Mar 31, 2009 | Canon PIXMA iP1800 Printer
LG dlp rear projection Tv model 56DC1D. When switching on the yellow light flashes for about 2 minutes then the red lamp light flashes twice before switching back to standby mode. The TV is approx 18...
First, check if any of the vents are clogged with dust. If not, try another lamp. They don't always look bad when they are bad. If you feel handy, by the lamp itself without the cage and swap in the new lamp. Make sure you do not touch the new lamp (finger oil is bad for the lamp. The oil creates a hot spot and early failure).
Nov 06, 2008 | Televison & Video
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
On: The printer is ready to print.
Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
Off: An error has occurred and the printer is not ready to print.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Synchronization problem
Set camera to Manual modes
Set Shutter to 60
Set Aperture to 5.6
Set ISO 400
Set lens at 10 feet
Subject at 10 feet
Turn on flash and wait until fully ready and do the following:
Set subject dead center, shoot with flash
Set subject to the right, " " "
Set subject to the left, " " "
Only the subject in center should have correct exposure.
Hope they are helpful.
Alexander
atdlee@netzero.com
Dec 14, 2007 | Sony HVL-F36AM TTL Flash
Ex & Built-in Flash
You need to do what is called an exposure lock. Aim at the subject, even if it's out of focus and half press your shutter. Then press the * button on the camera (top right) and it will exposure lock. You can then re-focus, but it will hold the exposure that was metered previously, so you'll get focus on a different object to what the camera has focused on. You can exposure lock anywhere, it doesn't even have to be your subject, it could be a nearby window to underexpose, or a nearby dark area to underexpose. Once you've locked the exposure you can focus somewhere else.
Dec 04, 2007 | Canon EOS 30D Digital Camera with 18-55mm...
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
HP DeskJet 5550 InkJet Printer Logo
27 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
