-   I had the same problem with Office Max cartridges. They flubbed me off, too. Needless to say I don't shop Office Max for much of anything anymore. Switched to Staples and they work just fine. -   Guest
Nov 03, 2008
-   Lexmark T630 with an Office Depot print cartridge. Constantly beeps, flashes error message, and requires a reboot to restart the printer.
-   ic3scrap3r
This is caused by an unsupported chip on the toner. If its a reman toner ie. Office depot/nice day then you should ring them up and et them to arrange for a new one. if they say its not possible to have a faulty one they will be trying to fob you off. just as a guide lexmark have around a 7% failure on toners so your not the only one. if it gets to the point where youd like to put the toner in a certain place of the office depot's worker then you can always find a chip online from people such as static or delacamp. and they just pull out and slide in.
my T630 prints a total black pages I try changing the toner but still the same black with other new...
(More)
my T630 prints a total black pages I try changing the toner but still the same black with other new toners
i want to now about Chip Messages of lexmark x340 is the chip full functional? i heard about...
(More)
i want to now about Chip Messages of lexmark x340 is the chip full functional? i heard about HP® P1005?/P1006?, P1505?, M1522? that Messages generated in HP1505 printer New aftermarket chip on cartridge: Printer will go to ready status. A message will pop up on the PC monitor after running a few pages that says Genuine HP Cartridge Installed. When the cartridge is low on toner a warning message of ?toner low? will pop up on the PC monitor. Used OEM chip on cartridge: Printer will go to ready status with the toner low warning light on and a message will pop on the PC monitor that says Used Cartridge Installed Any printer repair required as result of using non-HP supplies is not covered under warranty. This message will pop on the PC monitor randomly when data is sent to the printer. Note: Printer will print normally, but there will be no ?toner low? warning when the cartridge is low on toner. Using a cartridge without chip: Printer will go to ready status and a message will pop up on the PC monitor that says CARTRIDGE MEMORY ERROR ON BLACK Unable to read cartridge data. Re-install the cartridge. This message will pop up on the PC monitor randomly when data is sent to the printer. Note: Printer will print normally, but there will be no ?toner low? warning when the cartridge is low on toner. Engines have PC software that indicates if the cartridge is new or used. Do not post test chip with chip installed. what about lexmark x340 ? e260d ?
i have lexmark t630 printer, it works fine but every few hours it comes "error" on the...
(More)
i have lexmark t630 printer, it works fine but every few hours it comes "error" on the computer screen and stop printing. I turn off and turn on again and it works fine. Can you tell me why that happens!!! What will be the solution for that?
I have a couple of these printers with Fax machines on them. They will periodically hang with a...
(More)
I have a couple of these printers with Fax machines on them. They will periodically hang with a "parallel busy" message on the display. It cannot send or receive faxes until I print something else from the computer to clear the message.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
