Question about Kitchen Ranges
Cannon 10456g - Range Cooker - replace thermostat - fan oven
I need to replace a thermostat for a Cannon 10456g range cooker. I can easily get the part - I just don't know how to install it. Can anyone help?
SOURCE: Lofra MXD96AMFE/C Dual Fuel Range Cooker
Hi
The timer on our Lofra MXUD76MFE broke about 2 months after the 12 month warranty ran out.
Being a bit of a fiddler i took the top off the cooker to access the timer (not that difficult) when i ispected the timer i was astonished that it had lasted the 14 months it had such was the quality of it.
The timer was easy to set to ensure the cooker worked but unserviceable to restore the timer mechanism.
I thought given that it was such a cheap looking part (even allowing for the exorbitant price of parts) it would be worth replacing.
Came across the new appointed distributor - Premier Appliance Brands - based in Warrington (01925 248980)
They gave me a part No of 03010631 but didn't have stock and initially could not give me a price. i left it a couple of weeks and rang back this week.
They quoted £77 - needless to say i didn't order it
Posted on Nov 30, 2007
SOURCE: Small Electric cooker on Range does not reach temperature
The orange light is designed to go off when temperature required is achieved in the oven. If the light remains on it suggests that the oven is not heating, It could be a thermostat problem but it's more likely to be the element.
Posted on Jul 07, 2008
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
Posted on Jan 31, 2009
  • 21 Answers
SOURCE: fitting
Not familiar with this particular range oven but the thermostat should look like a longinsh cylindrical closed end metalic tube. You may have to raise up the cooking surface to run the wires for a new thermostat. If your oven is cooking to high or too low you can try taking the bake temp control off the know and see if there is a fine adjustement for temperature. I use a temp probe with a very inexpensive Sears DVM (about 20 bucks at Sears) to adjust mine. You should give the oven a good 1/2 hour to heat up and another 1/2 hour between each adjustment. Remember, the oven temp will swing high and low to maintain the set temp. Hope this helps!
Posted on Mar 13, 2009
I have a leisure range cooker. model number CMTF99R.The oven RHSis not Heating up. the fan is working and the thermostat light is coming on.
Check for voltage at the element, could be a hi-limit thermostat or a failure at the control board.... You may find you are missing one leg (half) of the 240VAC required to power the elements
Jul 31, 2016 | Leisure Range 90 CMTF95C Cream 900 mm Dual...
Cannon Chesterfield door latch
i need the door for my brown chesterfield main oven door cannot get it from cannon any help out there
louis.pratt@btinternet.com
Dec 02, 2012 | Cannon Chesterfield C60G Kitchen Range
Cooker oven not working - replaced bulb. Hot plates still work.
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 07, 2011 | Zanussi ZCE611X Electric Kitchen Range
Blows house trip when oven is turned on
Here is a diagram showing how the range receptacle should be wired. I would begin by checking there.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Apr 16, 2009 | Kitchen Ranges
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Fan assisted oven not working
If the fan is still working then it is the element that has gone. This is easily replaced as you only need to remove the back panel and swap the the element.
Nov 02, 2006 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
198 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
